Thread: Audi A4 demister flap motor
Results 1 to 10 of 10
  1. Audi A4 demister flap motor
    Dec 2007
    Hi . I have just purchased a " 52" A4 avant. The central demister does not work. I had it checked at Swifts & they said it needs a new flap motor installing which requires removing the dashboard & a lot of labour . I just windered if anybody had ever had similar probs & should i let Swifts sort it out or go the Audi dealers. Thanks - John .
  2. Re: Audi A4 demister flap motor
    andy5468 Guest
    i had exactly the same problem on my a4 2002 and was told the same thing when i rang the audi garage for advice.
    Big job he said to remove dashboard for access but i then discovered all you need do is remove the glovebox(4 screws) and this gives access to all the heater motors and flaps.
    In my case i was able to push the top lever arm(widscreen demist flap) whilst turning the demister button on and off and it started working.
    Whichever way i would recommend you try this first as it took me about 20 minutes and cost nothing!
    Audi probably wanted to charge me about £600 for this??
  3. Re: Audi A4 demister flap motor
    Dec 2007
    Hi Andy. Thanks for that very helpful information. I will certainly give it a go & see if it sorts out the problem. Cheers
  4. Re: Audi A4 demister flap motor
    Sep 2007
    Windsor
    If it is just the motor that's not working then just remove the glovebox and you'll find 3 motors on the right. The demister flap is the one in the middle (looking from top to bottom).
    If the flap itself is broken, which is unlikely then the dashboard will have to be taken apart! It's almost certainly or motor, or potentiometer problem. To check the operation of the motor once you've removed it, apply +12V across pins 5 and 6. The motor will run to it's stop, if you reverse the polarity the motor will run in the other direction.
    Hope this helps.
  5. Re: Audi A4 demister flap motor
    A, A
    Also resetting the flap motors can cure the problem.
    Just another B7 Estate
  6. Re: Audi A4 demister flap motor
    Dec 2007
    Yhanks again for all the helpful advice. Hopefully armed with this knowledge I might be able to sort it out myself. all the best - John
  7. Re: Audi A4 demister flap motor
    Dec 2006
    Quote Originally Posted by plexman View Post
    let us know how you get on... also on VAG-COm you can do a flap test..
    Rick
  8. Re: Audi A4 demister flap motor
    if you need a play with vagcom or need an output test doing and you're pretty local, drop me a pm and i'll sort you out
  9. Re: Audi A4 demister flap motor
    Dec 2011
    Swindon
    9 Post(s)
    Hello, I have recently got an A4 tdi 2004 and scanned it. it said
    "01809 - Actuating Motor for Temperature Flap; Left (V158)
    41-10 - Blocked or No Voltage - Intermittent"
    Is this the same problem as in this thread?
    IS there a DIY/HOW to guide to show me how to take out glovebox and replace motor etc.
    And the procedure for resetting it with VCDS?
    THanks
  10. Re: Audi A4 demister flap motor
    May 2012
    Everywhere
    308 Post(s)
    It's only a problem if the flap is stuck in the closed position not allowing outside air to be drawn in .
  1. airflow flap motor
    By mart2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2013, 01:27 AM
  2. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  3. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
  4. A4 Demister problem
    By scorpio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2007, 07:22 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    Last Post: 03-01-2007, 03:55 PM
