Thread: Can anyone please advise, new to Audi, really bad starting and running problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    Can anyone advise me please. I have just bought an Audi 80 Estate, 1992 on a K plate with a 2.0 litre petrol ABK engine. When I purchased the car it started first time and seemed to run OK (the person who owned it before told me they had just put the battery back on fully charged because it had gone flat while standing for several weeks). After driving for about half an hour, I stopped and the car refused to start again, I phoned the previous owner and was informed that there had been a similar problem about 2 years ago but it had been fixed since then (at the time of that problem an AA mechanic had come out and removed fuse 32, the car then started, the fuse was replaced and the car driven to a garage and no further problems of this nature occured after the garage had carried out work). Eventually the car started and I travelled about 100 miles folowed by a journey of about 160 miles a couple of days later, in the main during these journeys, the car purred along at around 60mph like a dream but once stopped was a pig to get running again, sometimes when it did start it ran really badly like it was 'missing' but then eventuall cleared, it would often not tick over properly when at lights and halt signs etc. (I also noticed that the dashboard temperature gauge was not working). I have experienced continual problems of this nature since and have been advised that the throttle body needs cleaning, the ECU needs resetting, sensors need replacing etc. etc. An audi garage told me the car was not new enough to be of the sort you can plug into a diagnostic machine, not that I can afford garage bills anyway. I have replaced a plastic manifold type unit on the side of the engine block (there was a leak from it) that houses two sensor type plugs, this was secondhand from a running engine and seemed for a while to have cured some of the starting and running problems for a while, I bought the unit complete with sensors and now my temperature gauge is working. I was also advised to change the idle control valve and I bought a complete unit from the same vehcle as before, this however made things worse so I went back to the original unit. The car ran OK for a couple of days with just one bout of stalling at traffic light and less problems starting, although it was not 100%. The other morning I went to start the vehicle and it would have none of it, I have run the battery flat trying and now have it off the vehicle on charge, has anyone got any ideas please. I have not been under the bonnet of a car for 30 years and although I built Ford cortinas and other vehicles of that era from scrap in those times I am completely stumped with all of this electrical sensor nonsense and am also not that familiar with fuel injection. The car has covered 150,000 miles and has a full Audi service history up to 121,000.
  2. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    133 Post(s)
    1986 Post(s)
    The most likely cause of your troubles is the blue temperature sender in that plastic water housing and your car does have (albeit primitive with 12 codes possible) diagnostics and with some live data output possible as well, so either the Audi person you were talking to was a numpty or far more likely a snob and was trying to get rid of you as your car is more than eight weeks old and "obviously you won't be in the market for a new one, sir!"
  3. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    Thanks Crasher, you might be right about the divey at the Audi dealership. I have changed the blue sender unit, albeit with a seconhand one but as my dash temperature gauge has started working since I was under the impression that it is OK. I keep finding a lot of info about problems after the battery has been disconnected, do I just reconnect the battery now it is charged and try again?
  4. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    133 Post(s)
    1986 Post(s)
    The gauge sender is separate to the ECU sender, black for the dash, blue for the ECU. The blue senders are useless, always failing-fit a new one.
  5. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    Thanks again Crasher, on the plastic manifold I replaced there is one blue sender and one grey, where is this black sender you mention?
  6. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    133 Post(s)
    1986 Post(s)
    Sorry, my mistake-the dash sender is a grey 3 pin on the ABK, not a black 2 pin.
  7. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    Is the blue one a 2 pin on the ABK?
    And do you know what kind of sensor should I get for the VDO oil temp gauge?
    Thanks in advance!
  8. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    You're better off asking a brick wall mate i'm on here looking for help!
  9. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    133 Post(s)
    1986 Post(s)
    What year 80 sport?
  10. Re: Can anyone please advise, new to Audi, really bad starting and running problems
    Dec 2007
    What year 80 sport?
    manufactured mid 1994
    tia
  1. Replies: 0
    Last Post: 15-12-2007, 04:37 PM
  2. audi A3 1.8 tsport running problems
    By Bazstrickers in forum Archive posts
    Last Post: 10-12-2007, 08:43 PM
  3. Audi S4 Starting Problems
    By S4AVANT in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2007, 02:55 PM
  4. Mk2 Audi 100 Starting Problems
    By Ayd in forum 100 - 200 - Turbo - 100 S4
    Last Post: 30-07-2007, 08:07 PM
  5. Audi A4 starting problems
    By sudderz in forum Audi A4 - Archive Topics
    Last Post: 01-02-2007, 10:25 PM
