Thread: Missing fuses?!!!
  1. Missing fuses?!!!
    S.E / Kent
    Hi there, I opened the fuse compartment on the driver's side and noticed that I have some fuses missing . i.e. No 1, 9, 41 and several fuses for ABS are fitted. The main reason why I went there in the first place was to check if the fuse for my alarm was blown coz its not sounding any more and I dont even know where to look for the siren box under the bonnet . Central locking works. Checked on the small card and there was no mention of alarm fuse or they may be using a diagram that am not familiar with representing the alarm. Does any one have a fuse diagram for a 9/1999 1.8 20v 125bhp? No water has gone to the wrong places yet. Otherwise the car is superb.
    Thanks.
    Redman
  2. Re: Missing fuses?!!!
    A, A
    I know on alot of cars, not all the fuses are there.
    Eg police lights, taxi equiptment, etc
    I havent a fuse layout though, sorry.
    Just another B7 Estate
  3. Re: Missing fuses?!!!
    133 Post(s)
    1988 Post(s)
    Look carefully into the empty locations, if you can see one metal connection point or none, no fuse should be fitted but if there are two connection points, there should be a fuse in that position.
  4. Re: Missing fuses?!!!
    Oct 2006
    Sunny slightly hilly Norfolk
    The siren is fitted on top of the nearside front wing under the bonnet. Check the connections first. I thought all the fuses were listed in the handbook.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  5. Re: Missing fuses?!!!
    S.E / Kent
    Thanks for replies. Had a good look at the fuse box next to the drivers door. All were intact as per crashers advice . However I got dismayed that am supposed to have heated side mirrors (i think fuse nine) as explained on the card plus the small knob on the door for side mirrors but there was no fuse and no metal connectors inside the two fuse holes. Any other place vw might hide the tiny fuses?
    Saw the siren for the alarm (passenger side) the connections seem fine so I think its the battery thats gone. How do I remove it and whats the part number? Or do I need to have a fault code done prior to touching anything?
    Redman
  6. Re: Missing fuses?!!!
    133 Post(s)
    1988 Post(s)
    The heated mirrors fuse isn't used on your version, they are powered from the convenience system.
  7. Re: Missing fuses?!!!
    S.E / Kent
    Many thanks crasher.
  1. Fuses!
    By tone70 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2008, 01:47 AM
  2. Mk3 Tdi fuses blowing
    By phil123 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 10:13 PM
  3. Missing fuses
    By eugoogoly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2007, 08:54 PM
  4. blowing fuses
    By majick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2007, 12:24 PM
  5. Lupo fuses
    By stephanie in forum Polo - Derby - Lupo - Fox
    Last Post: 19-09-2006, 11:48 AM
