Thread: RCD 300 - CD Problem
Results 1 to 8 of 8
  1. RCD 300 - CD Problem
    I've just been playing a mix cd in my Passat and was suprised to find that after every track it stops then starts the next track rather than the seamless flow it should be. I know this is something that can be remidied on iPods but can it be sorted on the RCD 300?
  2. Re: RCD 300 - CD Problem
    orangezorki Guest
    It's probably the CD, not the car. Go to the preferences in iTunes, then the advanced and burning sections, then select no gaps between tracks.
    David.
  3. Re: RCD 300 - CD Problem
    Funnily enough it's the actual cd not the ipod. When I play it through the ipod it's fine but when I had the cd it has gaps??? I'll stick to suing the ipod from now on!
  4. Re: RCD 300 - CD Problem
    orangezorki Guest
    Quote Originally Posted by chrisefc View Post
    Precisely - look in the burning preferences in iTunes and I'll bet it's set to add a 2 second gap between tracks.
    David.
  5. Re: RCD 300 - CD Problem
    Dec 2007
    Mine, does the same, I'm not happy.
    Just to correct orangezorki, this is a continuous mix cd not a rip on to an ipod. The cd should play with no gaps however the RCD300 stops at one track then starts at the next! Crap!
  6. Re: RCD 300 - CD Problem
    orangezorki Guest
    Quote Originally Posted by boofont View Post
    Sorry, I thought that you had ripped the tracks to iTunes and then burned a mix CD from it.
    David.
  7. Re: RCD 300 - CD Problem
    Well, just to add my 2p worth... It's hard to find MP3 players (CD and Flash/harddrive) that play mp3's one after the other without a gap.
    I'm a DJ myself and have had many players. So the RCD300 probably does have a gap between MP3 tracks...
    HOWEVER, if it's a proper Audio CD, then it will not have a Gap, UNLESS the CD has been burnt as Orangezorki suggests... with the 2second gap in place. Uncheck the 2second gap box, or look for a setting that says "Disc at Once".
    As for mp3's, the only way i believe, is by using some form of editing program, so merge each track and save t as one complete hour or so long track.... but then you'll have to fast forward through.
    On another note, i've heard the PS3 is good at playing mp3's continuously with very little gap.
  8. Re: RCD 300 - CD Problem
    May 2008
