Thread: gearbox trouble.
Results 1 to 8 of 8
  1. gearbox trouble.
    workington, cumbria.
    hi,last nite after work i was reversing and i think the gearbox went. there was a knocking and then kaput the car started t roll forward.
    im pretty sure its not the clutch as it still feels like it is tryin to bite now wen i try..
    wen i start the car now there is still a loud knocking from the gearbox.
    if any1 can shed any light whether it might be something simple or if the gearbox is shot would be great.
    oh the car is a 1.8 20v a4,1995.
    thanks
  2. Re: gearbox trouble.
    Quote Originally Posted by tatty0001 View Post
    thanks
    If the noise goes when you depress the clutch, its the gearbox not the clutch, as by doing this youre isolating the gearbox.
    If the noise is there all the time, could be several things. There is a dual mass flywheel on your car for one, and if thats given up completely it could fit your description. Likely you will have had some warning though with previous noise or clutch issues.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  3. Re: gearbox trouble.
    South Wales
    If the car was clicking when cornering before that, its probably a dead CV joint
    1.8t conversion : SP51x OUTLAW Turbo @ 25psi : Vmaxx Coils : 6 Speed 'Box : GripForce Stg 3 Clutch : S4 Leather : Facelift Console
    Anyone want to swap my A4 for an A3 or similar?? PM me
    243 bhp @ 6415 / 275 torques @ 3370 Chipped UK Rules
  4. Re: gearbox trouble.
    if it was a dead cv joint the car would still drive wouldnt it.
  5. Re: gearbox trouble.
    South Wales
    No,all the drive would go to the faulty one,just spinnig the shaft,but not driving the wheel
    Take a look,or rather get someone to see if anything is moving underneath when the clutch is released,that would at least rule that out.The gearbox's are preety solid,so unless you had prior problems,its unlikly that blew up
  6. Re: gearbox trouble.
    but would the car not stall when i put it into gear and released the clutch, thats what i meant.
    thanks for the info.
  7. Re: gearbox trouble.
    just looked under the car and the shaft that goes to the cv joint is just spinning, so does that mean its just the cv joint or could there be other stuff that has gone along with it. it was making a loud noise from the front of the engine bay which is still there,but am unsure if this has anything to do with the driveshaft or gearbox etc.
    thanks for allthe help guys, u might have just saved the audi from the dead.
  8. Re: gearbox trouble.
    South Wales
    The CV joint has gone, around £30 from ebay as a kit, 4 /10 for a diy repair IMO
  1. s4 gearbox trouble, has me baffled...
    By fannybatter007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2007, 10:26 PM
  2. LT trouble
    By maggotrunner in forum The Commercial Range
    Last Post: 23-09-2007, 09:58 PM
  3. gti trouble!!!!!!!!!
    By wadi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 12:00 PM
  4. Gearbox trouble
    By daddy in forum Touran - Sharan - Caravelle
    Last Post: 07-05-2007, 10:44 PM
  5. Gearbox trouble
    By oyam in forum Audi A4 - Archive Topics
    Last Post: 26-10-2006, 10:36 PM
