Thread: 1997 Audi A3 - Strange Beeping
Results 1 to 9 of 9
  1. 1997 Audi A3 - Strange Beeping
    Dec 2007
    I hope someone can enlighten me.
    My 1997 Audi 1.8 A3 makes a strange beeping noise (similar to an old 80s digital watch alarm but single beeps) and this beep only happens at the following time.
    1) When I am at the bottom of the blackwall tunnel in London
    It does also happen at other random times, however this blackwall tunnel beeping is regular as clockwork. Of note the blackwall tunnel is s steepish decent and then a rise up the other side.
    My thoughts are.. is this.
    1) Some kind of sensor that tells the A3 it is at some angle
    2) Some kind of "radio out of frequency" warning... (although it happens at other times)
    3) All in my head and I am insane
    Please help
    Richie
  2. Re: 1997 Audi A3 - Strange Beeping
    Dec 2007
    Quote Originally Posted by richiedc View Post
    Please help
    Richie
    Hi, I think I have a similar problem - did you get a solution? I am looking after my brothers Audie A3 for 6 months and it has started beeping - like a digital radio alarm noise, it does it about every hour - 6 or so beeps - if I unlock the car it stops, and when it does it again I lock it and it stops. what is going on? Can you help.
    Lesley
  3. Re: 1997 Audi A3 - Strange Beeping
    Dec 2007
    Lesley, no response. It is about 6 single beeps half a second apart. I dont lock my doors when driving so I dont think thats it.. seems to happen when the cars at an angle...
    most strange!
  4. Re: 1997 Audi A3 - Strange Beeping
    131 Post(s)
    1974 Post(s)
    Where in the car is the noise coming from? Is it possible it has a tracker?
  5. Re: 1997 Audi A3 - Strange Beeping
    Dec 2007
    Drove me to distraction yesterday so took it into garage this morning, apparently it is the back up battery to the alarm and the noise is not actually the alarm its the car horn. Will cost £70 for replacement and 2 hours labour so about £290 altogether.
    Thanks for your reply, have a good New Year!#
    Lesley
  6. Re: 1997 Audi A3 - Strange Beeping
    have you checked your oil , it sounds like the oil pressure bleeper going off , when the oils a little low if you go down or up steep hills or corner quickly you can sometimes uncover the oil pump pick up causing oil stavation and the low oil pressure buzzer/bleeper to go off when the oil recovers the pick up it stops
    Rob
  7. Re: 1997 Audi A3 - Strange Beeping
    Lesley, did you have the car repaired, and if so, has it resolved the problem. I have exactly the same symptoms, but am slightly confused over which part is at fault - the alarm or the siren - or are they the same thing.
  8. Re: 1997 Audi A3 - Strange Beeping
    High Wycombe, Bucks
    I had the same happen to me as I entered the Blackwall Tunnel yesterday.
    I thought it came from the radio and was either the RDS or the traffic updates being out of range.
    Mick
  9. Re: 1997 Audi A3 - Strange Beeping
    Have you tried holding down the TP button on the stereo? mine does this every now and again! solved it by doing this, it only happens when i have it on a certain radio station....i think it was KISS 100!?!
  1. Audi A4 2.8 Quattro 1997
    By gingimark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-05-2010, 12:59 AM
  2. audi a4 1997 stereo wiring help
    By brettcurran in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2007, 10:10 PM
  3. Hi,looking for A4 V6 1997 AUDI MANUAL
    By romano in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-05-2007, 05:27 PM
