Thread: Quick flashing indicators.
Results 1 to 10 of 10
  1. Quick flashing indicators.
    Sep 2007
    North Wales
    My 80 is suffering from quick flashing indicators on the drivers side. All bulbs are working, so it's not that. I had heard somewhere that it could well be the connections at the tow hitch, so I've disconneccted them all, but still no joy. The passenger side, however, has a bullb not working in the side repeater, but they flash normally, any ideas??
  2. Re: Quick flashing indicators.
    135 Post(s)
    2026 Post(s)
    Quick flashing should mean a blown bulb, so if the relay says 4x21+2x5 that means it is suitable for normal indicators and side repeaters so I imagine you must have a tow relay but that isn't normally required. I would check to see what relay you have first.
  3. Re: Quick flashing indicators.
    Sep 2007
    North Wales
    Thanks, I'll check that in the morning. Where do I find the relay, presume it's in with the fuses??
  4. Re: Quick flashing indicators.
    135 Post(s)
    2026 Post(s)
    It depends on the year.
  5. Re: Quick flashing indicators.
    Sep 2007
    North Wales
  6. Re: Quick flashing indicators.
    135 Post(s)
    2026 Post(s)
    On the relay plate under the dash, VW part number 1H0 953 222 with 21 or 191 on top for a 4x21w relay.
  7. Re: Quick flashing indicators.
    Sep 2007
    North Wales
    Found it. It says:
    TOP: 213 under which is embossed: PAS 8F30
    SIDE: (Audi sign) under which is: 443951253J
    SIDE: 12-8-94 )Presume date of manufacture
    SIDE: Circuit diagram.
    SIDE: SHO899511 60A 12V
  8. Re: Quick flashing indicators.
    Sep 2007
    North Wales
    The reason why the passenger side repeater isn't working is that a wire has come adrift. Someone said to me that the repeaters are linked and the fact that the passenger side repeater isn't working, could be the cause of the drivers side indicators flashing too fast!!!!! Can't say as I've heard anything like that before, but!!!!!!
  9. Re: Quick flashing indicators.
    135 Post(s)
    2026 Post(s)
    That isn't the indicator relay. 443 951 253 J changed to 8D0 951 253 which then changed to 7M0 951 253 A and it is the load reduction relay, also known as the "X" relay.
  10. Re: Quick flashing indicators.
    Sep 2007
    North Wales
    SORTED!!!!!
    I had a text from my step Son-in-Law todayto say that he had changed the rear bulb and had fitted an L.E.D. type bulb instead, this type presents no load to the relay, thus the relay thinks "Hmm, a bulb is not working, I'll go onto quick flash mode"!!
    Many many thanks, Crasher for your help. It's been a learning curve!
  1. A quick hello!
    By bikersi in forum New Member Introductions
    Last Post: 24-10-2007, 10:58 PM
  2. Indicators
    By baltiboys2 in forum 80 - 90
    Last Post: 23-10-2007, 11:07 PM
  3. Indicators not flashing!
    By misswhiz in forum Audi A3 - Archive Topics
    Last Post: 22-06-2007, 11:05 AM
  4. VW Passat Indicators Not Flashing
    By peco in forum Passat - Archive Topics
    Last Post: 29-04-2006, 10:15 AM
