Thread: Replacing a Broken wing mirror on a Sharan (housing and all)
  1. Replacing a Broken wing mirror on a Sharan (housing and all)
    Dec 2007
    Germany
    Hello all,
    New member and first post.
    In a brilliant display of stupidity I happened to wack my right side wing mirror on a cement block while parking my Sharan.
    The mirror is a wreck yet still attached to the vehicle. I can find plenty of replacement parts to replace the offended mirror but I have no idea if it is even possible to replace in my driveway or if I should take it to the VW service.
    The Sharan is over 9 years old so of course having it fixed is probably going to cost me a proverbial arm and leg.
  2. Re: Replacing a Broken wing mirror on a Sharan (housing and all)
    Mar 2007
    hi, its a simple job to replace , open the door and look opposite the mirror and you will see two plastic plugs, carefully prise them out and behind them is are two allen bolts, i think they are about 6mm but check , just undo them and the mirror will come away from the door as a complete unit .
  3. Re: Replacing a Broken wing mirror on a Sharan (housing and all)
    Dec 2007
    Germany
    Will all the control cables and wiring also be there?
    Will there be any problems with powered and heated mirrors?
    A Yank in Krautland
  4. Re: Replacing a Broken wing mirror on a Sharan (housing and all)
    Mar 2007
    the heated part is usually just two wires with a spade connector, the control cable if manual, is prob easier to leave attached and change the whole lot by removing the door card and taking out the control knob , it normally just pushes forward and then a quick twist and its out , have never tried to seperate the cable from the mirror, i would imagine its a bit fiddly! if its an electric mirror its just a matter of disconecting the wires.
  5. Re: Replacing a Broken wing mirror on a Sharan (housing and all)
    Dec 2007
    Germany
    Outstanding. The mirror is electric controlled so things should be easier. Just need to take a look.
    Thanks for the help.
    A Yank in Krautland
  1. A6 RH wing mirror cover...
    By gsxr-jon in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-11-2007, 09:39 AM
  2. 97 Arosa 1.0 MPI Wing Mirror
    By Terry Childs in forum Arosa
    Last Post: 24-07-2007, 05:08 PM
  3. Sharan wing mirror
    By iainherd in forum Touran - Sharan - Caravelle
    Last Post: 20-07-2007, 10:45 PM
  4. Polo 6n wing mirror
    By arryb in forum Polo - Derby - Lupo - Fox
    Last Post: 12-06-2007, 03:01 PM
  5. Replacing wing mirror glass
    By crx_paul in forum Passat - Archive Topics
    Last Post: 06-01-2006, 06:27 PM
