Thread: passat b5 problems
  1. passat b5 problems
    Dec 2007
    hello ppl please can some one help? firstly my passager puddle lights dont work on passenger front door neither does the central lockin when lockin from the internal switch?1 ne ideas? i also purchased a full set of suspension arms for my b5 and was wonder how good a quailty kit this is? oh n 1 last thing is it true climatronic has various over functions? if so how do i enter these? thanks for any response
  2. Re: passat b5 problems
    Assuming you have checked bulbs and fuses these two items run through the vehicles convienence control module which is located in the n/s/f footwell check to see if your carpets are wet like mine and if they are go and see ur bank manager for a resonably sized overdraft what make are the front suspension arms?
    Ed
  3. Re: passat b5 problems
    Dec 2007
    carpets are dry. shall check fuses later. just a mystery why it the only one not workin. thanks for the reply
  4. Re: passat b5 problems
    Come to think of it i had a similar prob on the back door of my car when i first took ownership there is a block connector inside the rubber boot which connects to the door and door pillar check the connector is still secure.
    Ed
  1. Passat problems
    By simonvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2007, 04:16 PM
  2. Passat electrical problems
    By nickw12 in forum Passat - Archive Topics
    Last Post: 15-09-2007, 02:39 PM
  3. 99 Passat ABS Problems
    By mmeinhold in forum Archive posts
    Last Post: 25-07-2006, 08:04 PM
  4. 99 Passat ABS Problems
    By mmeinhold in forum Chat - Completely Off Topic
    Last Post: 08-07-2006, 05:58 PM
  5. 2 X PASSAT, 2 X PROBLEMS
    By KJV in forum Passat - Archive Topics
    Last Post: 06-04-2006, 01:20 PM
