Thread: a4 2.5 tdi v6 1999
  1. a4 2.5 tdi v6 1999
    Dec 2007
    south oxon
    hi need help replacrd fuel pump in tank but still wont pull fuel upto filter used hand pump to pull to filter engine tries to fire then dies please help
  2. Re: a4 2.5 tdi v6 1999
    Dec 2007
    Its possible that you have an air leak in your fuel line upto the pump. Check fuel filter seals etc for leak.
    Have you replaced the filter?
  3. Re: a4 2.5 tdi v6 1999
    Dec 2007
    Hi there Rob,
    Looks like I have the same car.Never experienced this.
    If it's of any help try the flw, or ask your mechanic about:
    1.Was the new pump checked before installation?
    2.Was the power supply to the pump checked?
    3.Understood you're speaking abt the supply(feed)pump located in the fuel tank. Provide some direct supply to the pump and then bleed all the points up to the filter
    If you are not sure try not to do it yourself in order not to affect the car's electronics
    Pls update us with the development...
  4. Re: a4 2.5 tdi v6 1999
    Dec 2007
    south oxon
    found the problem injection pump timing 60degrees out dont know how but the timing pin holes were this far out so injecting to wrong cylinder
    cheers rob s
    83 standered golf gti
    83 modded golf gti
    02 seat ibiza
    99 audi a4 tdi
  1. 1999 A8
    By grizz in forum A8 - S8 - V8
    Last Post: 09-11-2007, 01:04 PM
  2. 1999 gt tdi [AHF] TURBO
    By madmonk in forum Golf MK4 - 1999 - 2004
    Last Post: 25-09-2007, 03:29 PM
  3. S4 1999
    By Ftagi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 01:54 PM
  4. T4 1999 Caravelle 2.5 TDI
    By andy123 in forum New Member Introductions
    Last Post: 13-07-2007, 07:45 PM
  5. A4 2.5 TD 1999 HELP Please Big problems
    By JamesB in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-01-2007, 02:20 PM
