Thread: Golf IV TDi Dashboard Lights (Pre-heating Device)
Results 1 to 10 of 10
  1. Golf IV TDi Dashboard Lights (Pre-heating Device)
    Dec 2007
    Abuja
    I noticed a particular yellow light coming on the dashboard and after consulting the handbook manual (in french), was able to understand the light means "Pre-heating Device". Could not get any one to rectify it and so took it for servicing after changing the oil, oil-filter and fuel filter, drove the car home (abt 30KM), parked and the next morning could not get the car to start till now.
    Someone should please help!!!!
  2. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Apr 2007
    N.Ireland
    Does the dashboard light look like the picture above? If so then this is the glow plugs light. Glow plugs are used in diesel engines to pre-heat the engine prior to it being started. When you turn the key, this light should come on for a few seconds then go out. Once it has gone out, you can then start the engine.
    Are you waiting until this light goes out before trying to start the engine?
  3. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Dec 2007
    Abuja
    Yes Chris that is exactly the light on the dashboard. Yes to answer your question, before now it comes up with other lights and goes off before the engine is started. It started blinking about 2 weeks ago after starting the engine prior to now that the engine is completely refusing to start.
  4. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Apr 2007
    N.Ireland
    If the light isn't coming on at all now and the car won't start, it sounds like maybe a problem with the glow plugs relay. It would be easier to diagnose if you could get the fault codes scanned using vag-com or some diagnostic equipment. Have a look at this link to see if it helps you any.
    http://forums.tdiclub.com/showthread.php?t=79819
  5. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Dec 2007
    Abuja
    Chris,
    How does one scan the fault codes using the vag-com?? I'll also like to confess that I've never seen the "vag-com" device/equipment before. Am going through the link sent to see how much help it will be, meanwhile I'll keep you posted of any thing I find out related to the noticed problems before now.
    Thanks once again
  6. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Apr 2007
    N.Ireland
    Vag-com is diagnostics software that you download and run from a laptop and it will scan your ECU for any faults that have been logged as well as letting you carry out other functions (although a licensed copy is needed for the latter). You also need a cable to connect the laptop to the cars diagnostics port (which is located just above the cigarette lighter/ash tray). A fault reader, which is a hand held device that again plugs into your diagnostics port and scans faults can also be used. Any good garage should have access to at least one of these things and if not eshrules from this forum sells both cables and code readers.
    Golf GTD 2.0 DSG (ACC | Winter Pack | 18" Vancouvers | RCD510 | Parking Sensors, Rear Camera & Park Assist | Cruise Control | Flat Tyre Indicator | Luxury Pack | Rear Airbags)
  7. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Dec 2007
    Abuja
    Chris,
    Want to say thanks for the link you sent me few days back. I eventually got someone to check the "heat plugs" and discover that the four are bad. Still checking other things that might not be working well. Will keep you posted and hopefully can start enjoying my car back after about 2 weeks of hiking buses..............
  8. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Apr 2007
    N.Ireland
    Good stuff, let us know if you get it sorted
  9. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Dec 2007
    Abuja
    Hello Chris, Unfortunately I don't have any good news yet despite the replacement of the heat plugs and other things detected to be bad. As it is the engine revs up and dies, the technician says it is "cutting fuel", and that the Injector Pump is the culprit. He loose it and we're yet to get the exact part anywhere. The one we saw is a manual pump and not an electric pump and I can't afford it, not in this season. This is the pic of the Pump he is suspecting. Am almost out of any fresh idea.
  10. Re: Golf IV TDi Dashboard Lights (Pre-heating Device)
    Apr 2007
    N.Ireland
    You may be able to get the pump reconditioned rather than buying a brand new one, could work out cheaper. Something to maybe look into. Never had it done myself so couldn't give you a rough price or even suggest somewhere that could do it, sorry.
  1. Help with lights in dashboard A4
    By Johanzen in forum Audi A4 - Archive Topics
    Last Post: 02-11-2007, 02:20 PM
  2. Golf 1.9tdi - Dashboard lights flickering
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-04-2007, 05:18 PM
  3. Dashboard Lights
    By tailor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2007, 01:30 PM
  4. dashboard lights
    By wax in forum Audi A4 - Archive Topics
    Last Post: 11-12-2006, 04:25 PM
  5. vw golf G reg dashboard lights
    By ponymoore in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-02-2006, 09:18 PM
