Thread: Beta manual,
Results 1 to 10 of 12
  1. Beta manual,
    Oct 2005
    Bristol
    Hello,
    Please can anyone help me. i have just bought a Beta stereo form my Mk3 Golf. However i would like to get my hands on a manual so I know how to put the code in correctly. as long as it is readable I'm happy, scanned or .pdf not fussy.
    Hope that some one can help.
    Regards,
    Mark.
  2. Beta radio
    derrynic Guest
    Hi, I was wondering if you ever had any luck with the Beta radio. I have just bought a mk4 golf and the radio wont let me input the code. It says SAFE2 on the display when turned on.
    Dec 2006
    Wiltshire
    If the unit says safe you will need to leave it switched on for at least an hour uninterrupted.
    After it has freed up it should switch on units says SAFE, then change to 1000. Enter code using preset 1- 4. Press >> to enter code number. If the display flashes and 1 appears it’s the wrong code number !
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    derrynic Guest
    hi thanks for the advice. just a quick quiery b4 i try it. are u saying put the code 1000 in or the 4 digit code in the manual in? also do i need to leave key in ignition or is ok to leave radio on with key out?
    Dec 2006
    Wiltshire
    No the display will show 1000 before it lets you put your code number in. You will have to leave the key in the accessory position or go for a long drive. The timer won't reset just by turning the radio on.
    derrynic Guest
    cheers mate, this is of great help, last thing, accesory position? is this turned twice so that dash lights light up or just the one turn of the key?
    Dec 2006
    Wiltshire
    On a Mk3 from recollection, I think you can just turn the key to the ignition position then back to the removal position but leave it in and the stereo will remain turned on.
    (Long time ago I had one - memory not what it used to be...)
    Don't leave it with the ignition on - things get hot that shouldn't when you do that.
  8. Re: Beta manual,
    meathead Guest
    Quote Originally Posted by MarkMk3 View Post
    Hello,
    Regards,
    Mark.
    Did you find the manual?
    Thanks!
  9. Re: Beta manual,
    Oct 2005
    Bristol
    No Never did, is it possible that you can help???
    Cheers,
    Mark.
  10. Re: Beta manual,
    meathead Guest
    No, I'm in the same boat!
    Didn't expect a crap product from VW. Oh well, must be a sign of the times!
  1. VW Beta Radio Help
    By dannyk in forum Polo - Derby - Lupo - Fox
    Last Post: 20-11-2009, 09:07 AM
  2. Playing your MP3 player/SatNav through your Beta etc VW radio
    By Julian Joyce in forum Archive posts
    Last Post: 10-09-2007, 09:28 AM
  3. In Dash CD Changer (Beta)
    By NickW in forum Passat - Archive Topics
    Last Post: 27-03-2007, 03:23 PM
  4. Beta radio problem
    By MarkMk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-09-2006, 02:34 PM
  5. Sharan SE - Beta Radio Cassette
    By warbum44 in forum Touran - Sharan - Caravelle
    Last Post: 28-02-2006, 11:24 PM
