Thread: bora ABS fault
  1. Unhappy bora ABS fault
    hi all........
    can anyone help me with my abs??
    my abs f/r/h wheel sensor has been showing a fault, it has now been changed twice 'by the same garage' and it has not cured the problem.
    the light is still on the dash and it will now not reset.
    i have checked the air gap and i think it is all correct. i have also checked the conection on the cable leading into the sensor.
    i do not know what to check next...... can anyone help???
    david
  2. Re: bora ABS fault
    Coventry
    has it been fault read by vagcom? it may need resetting using this.
  3. Re: bora ABS fault
    hi
    i think so, 8it went back to a local garage ( not vw) and they said it would not let them reset it. i assume this means there is still a fault on the f/o/s wheel..........
    do you know if there is any way of testing the readings fron the sensor??
    or what should i try next??
    thanks.......
  1. ABS fault
    By EVILUTION in forum Bora - 1998 - 2005
    Last Post: 11-10-2008, 09:44 PM
  2. bora fault p0401
    By DONNELLAN600 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2008, 06:23 PM
  3. ABs Fault
    By marcosoaleal in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-09-2007, 06:36 PM
  4. bora boot handle fault
    By kresher in forum Chat - Anything with wheels
    Last Post: 26-07-2007, 11:09 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
