Thread: A4 2001 Speed Sensor Fault
Results 11 to 20 of 22
  1. Re: A4 2001 Speed Sensor Fault
    If the engine speed sensor is faulty, the car won't run. Virtually the only one that doesn't have a default value. Maybe check the teeth and belt alignment
  2. Re: A4 2001 Speed Sensor Fault
    Not strictly true.
    Ours wouldn't start properly when the engine was cold; eventually it would fire up and then work fine until it cooled down again. Do a Google search - I think the A4mods.com site details the problem and the solution.
    When we fitted a new sensor, pinpointed by the fault code, the starting problem was cured.
  3. Re: A4 2001 Speed Sensor Fault
    Oct 2006
    bedfordshire
    Quote Originally Posted by Isoproturon View Post
    Not strictly true.
    Yes I think the same The fault has been there for months after changing the cam sensor the car starts no probs. If the cam belt has moved the engine
    would not pull properly.
    I am going to run vag com this weekend and post the results.
    Can anyone give me a part number for the speed sensor I may get one from Euro parts.
  4. Re: A4 2001 Speed Sensor Fault
    134 Post(s)
    2021 Post(s)
    PM me the chassis or reg and I will give you the number.
  5. Re: A4 2001 Speed Sensor Fault
    Oct 2006
    bedfordshire
    Hope this helps
  6. Re: A4 2001 Speed Sensor Fault
    134 Post(s)
    2021 Post(s)
    OK delete that info now.
  7. Re: A4 2001 Speed Sensor Fault
    #17
    134 Post(s)
    2021 Post(s)
    Not a good number anyway, PM me the reg.
  8. Re: A4 2001 Speed Sensor Fault
    #18
    Oct 2006
    bedfordshire
    1
  9. Re: A4 2001 Speed Sensor Fault
    #19
    134 Post(s)
    2021 Post(s)
    Delete that now.
  10. Re: A4 2001 Speed Sensor Fault
    #20
    134 Post(s)
    2021 Post(s)
    VAG 078 906 433 A £57.87 inc. VAT
    Bosch 0 281 002 222
    Hella 6PU 009 146-341
    Febi 24446
  1. speed sensor wire
    By Stu_c in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 09:29 AM
  2. A4 TDI - Engine Speed Sensor
    By philb80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 05:49 PM
  3. Transmition speed sensor G38
    By Sam in forum Archive posts
    Last Post: 10-05-2007, 08:53 PM
  4. speed problem with the A4 TDI 1.9 AVANT 2001
    By SAID in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2007, 01:49 PM
