Thread: A4 2001 Speed Sensor Fault
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. A4 2001 Speed Sensor Fault
    Oct 2006
    bedfordshire
    Hi All
    "Can anyone help !" I had a starting problem run Vag com Fault was the cam position sensor replaced that all ok on starting now but I am now getting a fault code on the Engine Speed Sensor (G28): Incor. Correlation.
    Does this point to the sensor at fault and I need to replace or is it a software
    job. If so can I do this with VAG-COM.
  2. Re: A4 2001 Speed Sensor Fault
    Don't know, try clearing the code with VAG-COM.
    One went on our 2.0 petrol recently but it showed a different message to yours. £50 later and it was fixed. One bolt to undo and a connector to unclip and the swap is done.
  3. Re: A4 2001 Speed Sensor Fault
    133 Post(s)
    1989 Post(s)
    That is suggesting a phase error between the two sensors, what engine code is this, a PD TDI?
  4. Re: A4 2001 Speed Sensor Fault
    Oct 2006
    bedfordshire
    Engine Code is AVJ 1.8T PETROL When the fault code is cleared using Vag com it comes back. If there is a phase error can this be corrected with Vag Com I only have ver 312 on my lap top.
    Any help will be greatly appreciated.
  5. Re: A4 2001 Speed Sensor Fault
    133 Post(s)
    1989 Post(s)
    I forgot to ask what the fault code number was.
  6. Re: A4 2001 Speed Sensor Fault
    Oct 2005
    Could be something like 00513 I think. Had a similar fault sorted under warranty on the wife's car.
  7. Re: A4 2001 Speed Sensor Fault
    133 Post(s)
    1989 Post(s)
    00513 would just be G28 no signal.
  8. Re: A4 2001 Speed Sensor Fault
    Oct 2005
    Then I bow out gracefully and let you pick up where I began to dabble.
    Don't you hate finishing someone elses half-assed work
  9. Re: A4 2001 Speed Sensor Fault
    Sounds more like a timing issue to me. If the timing belt is worn / loose or slipped a tooth, then this fault can occur as the ECM sees too much of an interval between the two sensor signals.
  10. Re: A4 2001 Speed Sensor Fault
    Oct 2006
    bedfordshire
    Cam belt changed about 10 months ago
    All was fine for about 6 months then the car was hard to start ran vag com
    pionted to the camposition sensor changed that noe starts first time and the car runs very well. Engine fault symbol is now showing seems to me the speed sensor may now be faulty.
    Do you think I need to check the cam belt for any missing teeth.
    I will run vag-com tonight to see what fault code is present I may get a new speed sensor and changed it and see if the fault gos.
  1. speed sensor wire
    By Stu_c in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2007, 09:29 AM
  2. A4 TDI - Engine Speed Sensor
    By philb80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 05:49 PM
  3. Transmition speed sensor G38
    By Sam in forum Archive posts
    Last Post: 10-05-2007, 08:53 PM
  4. speed problem with the A4 TDI 1.9 AVANT 2001
    By SAID in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2007, 01:49 PM
