Thread: Air bag warning light, Brake warning light
  1. Air bag warning light, Brake warning light
    Sydney Australia
    I have just purchased a 1995 Audi 80 Quattro (2.6l v6) The air bag warning light takes about 2 minutes 15 seconds to go out after the car is started. The garage won't give me a roadworthy cert until it is fixed. Any ideas on how to fix it. The owners manual says it should go off within ten seconds.
    The brake warning light is always flashing. The reservoir is full, the hydraulic fluid reservoir is also full (although, it looks like the previous owner has topped it up with atf or common hydraulic fluid, not the Audi approved mineral oil) This is also preventing me getting a cert, so any ideas as to likely cause and cure?
  2. Re: Air bag warning light, Brake warning light
    Gwent
    Link for how to bleed out the contaminated fluid, it's from the 20v site, but the v6 uses same hydraulic system. Not sure if you have pentosin brand in Oz? Also the Audi spec has changed, the new fluid is G004 000.
    http://20v.org/pentosin.htm
    If you are still having problems, brake light is triggered by fluid levels and low hydraulic pressure. This could be a worn pas pump, leaking 'bomb' (check valve) or leaking servo. So go for the tests here:
    http://20v.org/brakprob.htm
    Note the servo test needs to be done before the bomb is condemned as faulty.
    I don't know much about the airbag, I guess the controller could be checked for fault codes, the dealer should be able to do this or get hold of Vag - com?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Red Brake Warning light
    By fayraz in forum Archive posts
    Last Post: 26-11-2007, 01:09 PM
  2. Brake Pad Warning Light
    By darkskies in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-11-2007, 11:26 PM
  3. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  4. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
  5. Brake Pad warning light?
    By les in forum Passat - Archive Topics
    Last Post: 27-11-2006, 09:51 PM
