Thread: swap
  1. swap
    Seattle
    Is it hard to swap out seized 1.8t quattro 5speed and put in a tdi motor?
    I bought a 98 1.8t quattro with a bad motor and i found a tdi motor cheaper then the 1.8t
  2. Re: swap
    london/ UK
    Its a big job, you will have to switch fuel lines, g'box, engine, engine loom, driveshafts, suspension, ECU, instruments, keys, and a bunch of other stuff. Best is to get a donor car complete and to replace everithing it needs. Otherwise, get the petrol engine in and leave it as it is !
  3. Re: swap
    Seattle
    Quote Originally Posted by adamss24 View Post
    thanks for the reply..... I guess ill be sticking to the 1.8t motor.
    do the s4 guage clusters work with the 98.5 up 1.8's?
  4. Re: swap
    london/ UK
    It should, if its the same immo.2. If its a immo3 it might not work. Anyway, you will need someone with vag-com and the SecretKeyCode to transfer the info from the old cluster to the new one as the key and immobiliser needs codding to the new engine ! Not as simple as its sounds and the dealer charges big bucks to do ! Ideally, i would get the engine, keys and clocks from the donor car then swap the key blade from donor car keyfob with the one from yours. That will ensure that the car will start after transplant is completed...
  1. Engine Swap
    By Macyzfman in forum New Member Introductions
    Last Post: 06-11-2007, 09:55 PM
  2. swap a 1.8 for a 1.8t
    By cmcb a3 in forum Audi A3 - Archive Topics
    Last Post: 06-11-2007, 09:51 PM
  3. MK3 2.08V > 16V swap
    By gti_8v in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2007, 12:04 AM
  4. engine swap
    By sokbrock in forum Chat - Anything with wheels
    Last Post: 10-04-2007, 01:39 AM
  5. a4 interior swap
    By j555pre in forum Chat - Completely Off Topic
    Last Post: 12-09-2006, 08:28 PM
