Thread: mk 2 weber co trouble
  1. mk 2 weber co trouble
    oxford
    hi there i am new to the forum world, i have a mk golf 1.6 and i have put a weber on it, but i can't seem to get the CO set up properly and it keep bogging down when i go to set of quickly and it doesn't have much at the top end either it also has a k & n filter on it that replaces the air box and 17" wheels and i'm not sure wether the wheels are the problem if any one has any suggestions they would be much appricated
    stu mk2 16
  2. Re: mk 2 weber co trouble
    neileg Guest
    The carb probably needs rejetting and setting up a rolling road. May have factory jetting that won't work at all with the K&N because that will produce a very weak mixture. Other possibility is that you have an air leak due to something about the installation not being correct.
    The wheels won't affect performance unless the tyre profiles are too big as this will increase the gearing, the carb needs sorting first
  3. Re: mk 2 weber co trouble
    oxford
    ok thanks ill look into that thanks for the advice
    stu mk2 16
  4. Re: mk 2 weber co trouble
    131 Post(s)
    1976 Post(s)
    You are probably suffering from carb icing, the Pierburg is bad for this but the Weber is terribly prone to it. Refit the original air box making sure the hot air pickup on the manifold is intact and that the correct composite hose (NOT aluminium, this cools the hot air) from the pickup to the air box is used and that the hot/cold air blend unit is working. You can test for this by looking down the cold air intake of the air box and as the engine starts, in this cold weather, the flap in the air blend should lift up to bring in hot air.
  1. fitting a weber 32/34 carb to a golf mk2
    By steve0 in forum Archive posts
    Last Post: 02-01-2008, 09:41 PM
  2. LT trouble
    By maggotrunner in forum The Commercial Range
    Last Post: 23-09-2007, 09:58 PM
  3. gti trouble!!!!!!!!!
    By wadi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 12:00 PM
  4. Fan trouble.
    By Danozeman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-05-2007, 05:30 PM
