Thread: Audi 80 location of blower motor relay pack
  1. Question Audi 80 location of blower motor relay pack
    The heater blower on my 1993 Audi 80 only works when the switch is in the full speed postion. I understand that the most probable cause is the relay pack. Can anybody tell me how to get to it? Cheers.
  2. Re: Audi 80 location of blower motor relay pack
    Gwent
    Sounds like it's the resistor pack? I think it's on the blower motor itself or close by. It's up behind the glove box. If you take the glove box out, you should find it. If you need to remove it, the blower motor detatches like a light bulb
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Audi 80 location of blower motor relay pack
    Hi i have been told that it could be the relay for the blowers is this correct.?
  4. Re: Audi 80 location of blower motor relay pack
    Gwent
    If the blower works at its full speed, but not one or all of the others, my money would be on the resistor pack.
    I'm no spark, but as I understand it, the blower fan gets a direct 12v supply at 4, its highest speed setting. At speed 3 it passes through 1 resistor (or 1 section of the resistor) this drops the voltage a bit which reduces the speed. at speed 2 it passes through 2 resistors (or sections of resistor) which drops the voltage a bit more, at speed 1 it goes through 3.
  5. Re: Audi 80 location of blower motor relay pack
    Thanks for the advice, I'll have a look at the weekend.
  6. Re: Audi 80 location of blower motor relay pack
    Scotty33,thanks for the advice it sounds to me like you should be a spark.I will let you know how i get on ,when i get a chance to have a look.
  1. Sharan - Heater Blower Motor Brushes
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 18-02-2009, 10:39 PM
  2. 1999 Sharan location of glow plug relay?
    By SeanieMac in forum Touran - Sharan - Caravelle
    Last Post: 29-11-2008, 10:53 PM
  3. Blower Motor!
    By welshcokes in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2007, 10:30 AM
  4. S reg A3 - Accessing Heater Blower Motor
    By kimi in forum Audi A3 - Archive Topics
    Last Post: 26-10-2007, 10:54 AM
  5. blower motor niose on a4
    By mark.ogg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-06-2007, 07:54 PM
