Thread: clutch juddering on biting point....
Results 11 to 20 of 32
  1. Re: clutch juddering on biting point....
    Quote Originally Posted by bonerp View Post
    I dont know whether this would help or hinder, but some Scooby Impreza Turbos have a habit of clutch judder when cold. The way owners tend to get ride of it is to raise the revs right up then drop the clutch - as tho you are launching on a drag strip.
    Always sorted mine!!! Was quite good fun too - just have to find a long straight road without much traffic on!
    We put it down to contaminated plates that needed cleaning.
    Paul
    More likely glazed than contaminated mate. Oil/grease contamination tends to soak into the plate rather well being a porus material.
    The reason why scoobys have a habit of this, is because glazing is caused by over heating..... something scooby drivers are good at!
    I'm sure the method you describe works ok at the time... but you are shortening the life of the plate, with racing starts causing the problem in the first place.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  2. Re: clutch juddering on biting point....
    Sep 2007
    well if its knackered and the only way to clean the face to stop the vibes is to drop the clutch then its the only answer!? Apart from a new clutch and fly.
  3. Re: clutch juddering on biting point....
    Agreed. All i was saying is that its not a clutch fault that causes the problem in the first place, its driving style
    2019 Urus, 2020 RS7
  4. Re: clutch juddering on biting point....
    Sep 2007
    Quote Originally Posted by Pauloz View Post
    like that was gonna change lol!
  5. Re: clutch juddering on biting point....
    london/ UK
    Hi, i suggest you guys have a diagnostic done, as in some cases, the engine active mounts will shake hard when defective and throw a code....Seen that on a few PD 130 and my a4 did it once or twice, but its only ocassionally ! If its constant judder, regardless with engine hot or cold, then its the DMF.
  6. Re: clutch juddering on biting point....
    Dec 2007
    West Sussex
    Thats interesting. Mine only judders when cold and not always... only sometimes; haven't found a pattern yet. What codes were you getting Adam? I might get mine diagnosed.
    Rob
  7. Re: clutch juddering on biting point....
    #17
    Dec 2006
    As a totally isolated fault I had my 'oil filled, electronically controlled' engine mount replaced a few months back. I didn't sense any problem but when Audi serviced the car they plugged the computer in and there was a fault code there.
    I have had my gear box removed and diagnosed. The Flywheel seemed to be the culprit. Through some sever arguing I managed to get it replaced on the used car warranty I have on the car (Not an Audi one) The whole car drives really nicely now.
  8. Re: clutch juddering on biting point....
    #18
    Hi All, Audi A4 1.9tdi 2001 100bhp
    Picked it up last weekend and it's been fine but when stuck in stop start traffic, after about 15 minutes of moving slowly i started to get this clutch judder. It appears to be only after slow driving and is gone again the next morning. It's going back on Saturday anyway to have the front discs changed. What is the most likely culprit so I can get them to have a look at that as well? Also, if I have to pay for it what's the likely cost?
    Cheers for your help
    Dan
  9. Re: clutch juddering on biting point....
    #19
    Quote Originally Posted by Hitby View Post
    Dan
    Likely to be the clutch friction lining is worn bud - it needs changing, and quick, before it damages the dual mass flywheel it runs on which is a whole heap more dosh (if youre paying for it....?)
    As for cost - where from? Dealers or independant?
    2019 Urus, 2020 RS7
  10. Re: clutch juddering on biting point....
    #20
    thanks for that, it would be an independent. Don't suppose you have an average price? What's involved labour and parts wise?
  1. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  2. A4 Avant 1.9TDI High Clutch Bite Point
    By jackreacher in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-11-2007, 09:03 AM
  3. Clutch biting point too low - A3
    By SimonPopp in forum Archive posts
    Last Post: 14-10-2007, 05:18 PM
  4. Clutch biting point lower after Emergency Stop
    By gbrownlee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-08-2007, 04:02 PM
  5. CLUTCH BITING POINT TOO HIGH
    By shabs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2007, 07:29 AM
