I have just fitted a chorus I head unit to 1996 model , however having a problem geting full volume from the rear speakers
Re the wrining . I have connected the battery live, earth and illumination to the unit
I have connected the front speakers to the unit and they work fine (there are only front speaker outlets on the 8 pin plug)
When connecting the rear speaker with the 6 pin plug I can obtain only slight sound through the rear (LR and RR and com are selfexplantory)
If I double up the left and reight speakers through this plug (ie 2 x right and 2 x left) all speakers work perfectly .
I guess this has somethng to do with the amp , as there is a white wire in the loom and am not sure if this is for the aerial or the speakers)
If for the speakers I guess this is powever to them - how do you get power to this ?? direct from the battery feed ??
Previously there was an aftermarket sony job which had a spaghetti junction of wires behind
all help gratefully received otherwise I shall just go without the fade function
