Thread: Drivers side Window removal
  1. Drivers side Window removal
    How do you take the door card and handles off , the window has come off iits runners and won't stay uo, but I cannot get the handle and switches off. Can anyone help??
  2. Re: Drivers side Window removal
    Sorry its a 1996 Mk3 GTI
  3. Re: Drivers side Window removal
    Jan 2006
    Leigh
    To get the window winder off, there is a funny "U" shaped spring clip between the window winder and the door card. Once this is removed the winder should pull off.
    The door handle is held on with screws, so unscrew them, same for the handle inside to open the door.
    The door lock pins which you pull up/push down to lock the car just unscrew and pull out, but they might be stiff.
    Once all thats off the door card is just clipped into place by some strong clips and should just pop off (with a bit of effort). But be careful not to break any of the clips when removing the door card.
    And be carefull of any wiring for the speakers and electric stuff, you should be able to unplug all of this.
    Info taken from the haynes manual.
    '99 B5 Passat 1.8 T 20v Sport
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. water in drivers side footwell
    By baj25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 04:48 PM
  3. Drivers Side Electric Window not working
    By philpg00 in forum Touran - Sharan - Caravelle
    Last Post: 24-04-2007, 01:37 PM
  4. drivers side electric window fault
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2007, 04:22 PM
  5. Drivers side Mirror cracked! RHD
    By Turkster in forum Passat - Archive Topics
    Last Post: 18-10-2006, 11:51 AM
