Both my radiator fans come on every time I switch on the ignition/engine EVEN when the engine is cold,the coolant temperature is normal according to the A/C direct code access.I've changed the TEMPERATURE sender & the thermostat.The only thing I've not changed is the radiator fan switch.Is there a relay that activates these fans ,If so where is it located.
ANY BODY OUT THERE ANY IDEAS?
