Thread: 2001 Passat Estate rear luggage light
  1. 2001 Passat Estate rear luggage light
    I had problems with rear luggage light would not go out when door shut - alarm on dash flashed rear door open and then main alarm would sound when parked and locked - removed bulb but still exterior alarm sounded - removed rear tailgate panel and discovered rear wiper water hose was loose and water sprayed everywhere so reconnected hose - and gave electric fittings/locks a light spray with penetrating oil hoping this would fix light but no. So just disconnected wiring to lock switch - no more alarm but no light - any ideas ??
  2. Re: 2001 Passat Estate rear luggage light
    It is the micro switch in the lock, renew it and it will sort things out for you,make sure the pins in the connector,are not damaged.
  3. Re: 2001 Passat Estate rear luggage light
    thanks, is micro switch part of lock? - and is it easy to change
    cheers
    A
  4. Re: 2001 Passat Estate rear luggage light
    It is a loose part pressed into the lock,quiet easy to change
  1. rear lights on passat estate
    By thebear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-09-2007, 08:29 PM
  2. A3 year 2001 rear fog light - how many
    By davetails in forum Audi A3 - Archive Topics
    Last Post: 27-07-2007, 11:31 AM
  3. Passat estate - rear ashtray
    By gibo.drum in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-04-2007, 07:08 PM
  4. Passat V5 Estate 2001 (Y)
    By Come_On_You_Irons in forum Passat - Archive Topics
    Last Post: 03-07-2006, 03:21 PM
  5. 130 SPORT ESTATE. Water in REAR LH light well!
    By EddyStone in forum Passat - Archive Topics
    Last Post: 19-03-2006, 06:32 PM
