Thread: ABS fault
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. ABS fault
    please please please help me...... my girlfriend 1999 bora (1600cc) has been having the ABS light come up on the dash for a while now and the ABS comes in on very soft braking. It is not constant and only happens whenever it feels like it. It has been to a local garage and VAG, they both have said its the F/R/H wheel sensor.............. it has now been changed twice and its still the same.
    they have checked the air gap, and found it to be all ok.
    Is there anything else i can do/check/clean?
    please help me as she is now using my car!!!
  2. Re: ABS fault
    Oct 2005
    Welcome to VWAF
    You've had the wheel sensor changed twice and the fault remains?
    I don't want to be too obvious, but have you had the fault codes cleared after each sensor change?
    Do you have the results of their code scans that you can share?
  3. Re: ABS fault
    134 Post(s)
    2022 Post(s)
    If there is no fault code the wheel speed data for each wheel needs to be studied on diagnostic equipment such as VAG-COM at very low speed to see which sensor is dropping out. This is a common problem, especially after a wheel bearing has been changed. It is sometimes necessary to file down the brass mounting point of the sensor to get the gap down to the required 0.3-mm.
  4. Re: ABS fault
    i have to assume that the code has been reset, however i will ask the mechanic later this eve...
    i have never done any repairs on ABS befor, but can you advise me on what to check as i will be taking wheel off tommorrow and having a look..
    Assuning i was fitting a new sensor, what steps should i take??
    thanks all....
  5. Re: ABS fault
    134 Post(s)
    2022 Post(s)
    Check the air gap between rotor and sensor is approx 0.3-mm.
  6. Re: ABS fault
    Nottingham
    Hi Crasher
    I have this same problem. I changed my rear wheel bearings last week, and now I am getting abs and brake light illuminated on dash. I have done VAG diagnostics and its coming up with speed sensor on rear passenger side. Is it worth replacing the speed sensor? or like you said to file down the brass mounting point? Is this the moiunting point of the sensor? If so do you have any pics? Is this easy to do DIY?
    Any step by step instructions?
    please help!!!
  7. Re: ABS fault
    Nottingham
    Hi Crasher
    Do you have step by step instructions please?
    please help!!!
  8. Re: ABS fault
    134 Post(s)
    2022 Post(s)
    What car is this on and the year? I have only had an air gap problem on the front of a Golf 4.
  9. Re: ABS fault
    Nottingham
    It is an 1996 Audi A4 1.9 tdi. Its on the rear wheel passenger side.
  10. Re: ABS fault
    Oct 2005
    I thought (dangerous I know) that this was a fairly common problem across the range?
    I had an air gap issue after pummelling the heck out of the flippin' pinchbolts when I changed my suspension.
    I had to remove and reseat the sensors to get the light to go off.
  1. ESP Fault
    By jb8591 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-11-2007, 06:50 PM
  2. Air con fault - help!!
    By LeeinBunwell in forum New Member Introductions
    Last Post: 13-10-2007, 07:59 PM
  3. ABs Fault
    By marcosoaleal in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-09-2007, 06:36 PM
  4. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  5. ABS Fault
    By mygolfvr6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2006, 07:37 PM
