Thread: Polo Cycinder head replace
  1. Question Polo Cycinder head replace
    Hello,
    I've got a VW Polo 1.2E, Recently it suffered a misfire on cylinder 3 I was advised to replace coil pack so I did. Then more recently I began misfiring again I took it to VW for a service as it was due and this it what they said:
    "carried out compression test
    check due to missfire.On all cylinders number 3 cylinder
    verry low on compression 05.3 bar should be around 15-16
    bar.We reccomend cylinder head removal to check valves
    for movement. may require cylinder head overhaul.and
    refitted with new gaskets and seals.
    refitted with new gaskets and seals."
    Now for all the work the quoted me an astromomical amount of just shy of 12hundred!
    Does anyone here know if i'm being ripped off? how long should a job like this take? Does anyone know a trustworthy place around wolverhampton where I could get a second opinion? Is this the best course of action? This is the first time i've come across a problem like this and faced a bill so large...
  2. Re: Polo Cycinder head replace
    Sorry to hear you've got such expensive problems.
    A cylinder head removal is a big piece of work and while not technically demanding, it will be a lot of labour. And changing valves properly is no straight-forward task.
    Their price looks not unexpected but definately shop around, like anything. Or give it a try yourself
  3. Re: Polo Cycinder head replace
    2019 Post(s)
    This is a very common problem on the 6 and 12 valve 3 cylinder. A new VW exchange head is £500 or £600 respectively so taking into account the extremely recommend fitment of the timing chain update set, gaskets, bolts, coolant, filter, plugs, labour etc that price is about spot on. A VAG specialist would probably knock about £200 off that and if they still used all genuine parts this would not invalidate the two year warranty (labour included) that a VAG exchange cylinder head carries.
  4. Re: Polo Cycinder head replace
    Thanks guys, i've phoned around some local independant garages and getting quotes averaging £450 (A Third of the VW price!), i know the parts won't all be VW genuine but the vehicle isn't in warrenty anymore do it won't make much difference. Still cash that i dont want to part with over the festive period.
  5. Re: Polo Cycinder head replace
    2019 Post(s)
    That won't include changing the cam chain and tensioners, this must be done. If it jumps later it will bend valves and all have to come apart again at your expense. Please do not shop on price alone, all that will happen is that the job will not get done properly. Ask these people if they give a 2 year warranty on the work. The car being in or out of warranty doesn’t make any difference.
  6. Thumbs up Re: Polo Cycinder head replace
    Nice one Crasher you sure know your stuff. Thanks for the advice. I found a place which looks reputable that speacialise in engine reconditioning. They think it could be a valve replacement but they say they'll check it out first. That's the problem because it sounds like it could be a variety of faults with different resolutions. From what i gather it will definatley involve the removal and re-fitting of the cylinder head.
  1. Polo Clinder Head Removal
    By micky2000 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2008, 06:25 AM
  2. Sunroof? Fix or replace
    By WJI8985 in forum 80 - 90
    Last Post: 08-07-2007, 06:09 PM
  3. VW Polo Gti alarm, doing my head in!
    By mobbs in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2007, 06:26 PM
  4. polo ventilated disk replace
    By paulprd in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2007, 09:37 AM
  5. bin em save em replace em
    By sean red i in forum Chat - Anything with wheels
    Last Post: 23-03-2007, 08:29 AM
