Thread: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
  1. Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    Jan 2014
    Bicester
    Can anyone point me in the right direction definitively as to which pins on which connector go to the coolant temp sensor on a EDC16U34 on a 2007 1.9 tdi BXE?
    So far from ChatGPT etc. I've had about 4 different answers and am not yet ready to go down the route of an erWin subscription
    Many thanks.
  2. Re: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    135 Post(s)
    2043 Post(s)
    Not ready to spend £6.90... This is May 2006 onwards.
  3. Re: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    Jan 2014
    Bicester
    Thanks! Is it only £6.90? Is that for an hour? Cheers.
  4. Re: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    135 Post(s)
    2043 Post(s)
    €10 an hour of €30 for 24 hours, so if time time it right you have two days of access to download and save as a PDF, everything you would ever need but you need some decent disc space.
  5. Re: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    Jan 2014
    Bicester
    Thanks. I've registered and will download what I need for the second and final issue I hopefully have for now.
  6. Re: Which pins on ECU are for G62 CTS?? 1.9 TDI BXE
    135 Post(s)
    2043 Post(s)
    I use Cute pdf, very quick and easy.
  1. Question What are Turbo Pins ???
    By Jim Paton in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-05-2011, 12:15 AM
  2. OBD CAN bus pins
    By Borab0y in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 16-11-2010, 07:09 PM
  3. Key Fob Pins
    By Hillsy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-12-2009, 05:27 PM
  4. Important Door Pins
    By PAT_GT_TDI in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2008, 07:35 PM
  5. Door Pins
    By mwsrosso in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 05:11 PM
