Thread: VW Passat CC 2014
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: VW Passat CC 2014
    #11
    135 Post(s)
    2038 Post(s)
    As long as it is a legit interface.
  2. Re: VW Passat CC 2014
    #12
    Oct 2025
    South Shields UK
    Code:
    Wednesday,15,October,2025,12:23:08:16365
    VCDS Version: 25.3.2.0  HEX-V2 CB: 0.4672.4
    Data version: 20250822 DS365.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZEP009398
    License Plate:
    Mileage: 484080km-300793mi
    Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 11 31 15 16 17 19 25 2E 37 42 44 46 4C 4F 52
              53 55 56 61 62 6C 72
    01-Engine -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    11-Engine II -- Status: Cannot be reached 1100
    31-Engine other -- Status: Cannot be reached 1100
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes        Labels: 3AA-614-109.clb
       Part No SW: 3AA 614 109 AQ    HW: 3AA 614 109 AQ
       Component: J104   C2 450M VD23 0030
       Revision: --H07---    Serial number: 00000007988037
       Coding: 0010000
       Shop #: WSC 05311 000 00001
       VCID: 7CA1F4ED5AE8993AD2B-8028
    8 Faults Found:
    01042 - Control Module; Not Coded
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 22
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 21:45:56
    Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 10.75 V
                        Bin. Bits: 00011111
                        Count: 216
                        Hex Value: 0x0000
    00576 - Terminal 15
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 9.75 V
                        Bin. Bits: 10000000
                        Count: 128
                        Hex Value: 0x0000
    03201 - Adaptation Overboost
                005 - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    01423 - Lateral Acceleration Sensor (G200)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    01279 - Longitudinal Acceleration Sensor (G251)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    00810 - Sensor 1/2 for Brake Pressure
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    01542 - Yaw Rate Sensor (G202)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    00778 - Steering Angle Sensor (G85)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:56
    Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
       Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
       Component: Climatronic   H05 0505
       Revision: 00001K02
       Coding: 071400C849
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_VW46.rod
       VCID: 0059801D3A80FDDA8E3-8054
    3 Faults Found:
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [00001001] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:06:29
    9601329 - Humidity sensor
              B1281 31 [00001001] - No Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 6
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:06:29
    9481748 - High Pressure Sensor
              B10AE 14 [00001000] - Open or Short to Ground
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 23:34:00
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0018
       Revision: --------    Serial number: 28261408703062
       Coding: 308004
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_EPHVA18VW47X0000 001006
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3FDB43E107FE4222B79-806A
    2 Faults Found:
    13635840 - Supply voltage
              U1011 00 [00001000] - Voltage too Low
              [Versorgungsspannung - zu niedrig]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 22:24:06
    13893632 - Function Restricted due to Insufficient Voltage
              U1400 00 [00001000] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 22:24:06
    Address 11: Engine II
    Cannot be reached
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__70J VW10 HI   2518
       Revision: 27019000    Serial number: 003L7P6S2017
       Coding: 0012362
       Subsystem 1 - Serial number: 6332MTS653980624
       Subsystem 2 - Serial number: 6342MTS654220624
    Subsystem 3 - Serial number: 6351HTS60I2OOCKJ
    Subsystem 4 - Serial number: 6361HTS62VC0OCKR
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    2 Faults Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - MIL ON
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:06:44
    00532 - Supply Voltage B+
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:05:08
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 DA    HW: 5K0 953 569 BA
       Component: LENKS.MODUL   016 0140
       Revision: FF010042    Serial number: 20140321101646
       Coding: 0182270000
       ASAM Dataset: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 678BBB813FEE2AE22F9-8032
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H07 0022
       Coding: E20000
    1 Fault Found:
    1140738 - Steering angle sensor
              B1168 54 [00001001] - Missing Calibration / Basic Setting
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:06:43
    UBat: 11.30 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 970 N    HW: 3AA 920 970 N
       Component: KOMBI         H04 0811
       Coding: 460D01
       Shop #: WSC 00028 028 00020
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
       VCID: 3E253EE500F44B2ABCF-806A
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
              [Steuergerät für Motor: keine Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:06:47
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 210314F1003415
       Coding: 469007
       Shop #: WSC 05314 000 00001
       VCID: 7CA1F4ED56E8993AD2B-8028
    4 Faults Found:
    01314 - Engine Control Module
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 21:51:30
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 21:51:34
    01342 - Engine Control Module 2 (Slave 1)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 21:51:30
    00576 - Terminal 15
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:48
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         043 0407
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 382928FD2E50751A763-806C
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    No fault code found.
    Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
       Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Component: SG EXT.PLAYER H19 0770
       Revision: A1001003    Serial number: 7666050104
       Coding: 020100
       VCID: 2B0307B1E306CE820B1-807E
    Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
       Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
       Component: RNS315-EU   H36 0263
       Serial number: VWZAZ2M3922191
       Coding: 0400040104000F0000019202
       Shop #: WSC 00222 210 104156
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS_VW32.rod
       VCID: 270BFB81FF6EEAE2EF9-8072
       Data carrier:
       Subsystem 1 - Part No: 3AA 919 866
       Component: EUR_W_0038  0038
    6 Faults Found:
    1048580 - Function Restricted due to Insufficient Voltage
              [restriction due to undervoltage]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 22:07:12
    1048598 - Front Right Treble Speaker
              B1064 13 [00001001] - Open Circuit
              [tweeter front right open load]
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:05
    1048636 - Digital Radio Antenna
              B1103 13 [00001001] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:03
    1048661 - Function Restricted due to Missing Message(s)
              U1111 00 [00001000] - -
              [CAN TO park distance control]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 23:33:56
    1048650 - Telephone baseplate
              B1051 13 [00001001] - Open Circuit
              [baseplate open load]
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:03
    1048642 - Internal Control Module Memory Check Sum Error
              B2000 42 [00001001] - General Memory Failure
              [ECU defect data memory failure]
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Mileage: 150711 km
                        Date: 2020.10.26.
                        Time: 20:16:13
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0556
       Revision: 12110009    Serial number: 0008320215
       Coding: 0202B7
       Shop #: WSC 05311 115 00001
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
       ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
       VCID: 6D87C9A91D1200B2555-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  005 0501
       Serial number: 00000003909511
       Coding: 010090
    3 Faults Found:
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [00001001] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 22:26:35
    68107 - Function Restricted due to Missing Message(s)
              [Front CAN AirBag]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 23:33:55
    68108 - Function Restricted due to Missing Message(s)
              [Front CAN MSG]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 21:58:31
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 207    3501
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 392F2DF9155A6C1289D-806C
    2 Faults Found:
    03803 - Steering Angle Sensor for Steering Aid
                005 - No or Incorrect Basic Setting / Adaptation - MIL ON
                 Freeze Frame:
                        Fault Status: 11100101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:07:11
    Freeze Frame:
                        Battery Volts: 11.2 V
                            DU
                        Temperature: 21.0°C
                        Count: 3
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:05:42
    Freeze Frame:
                        Voltage: 9.50 V
                            PD
                        Temperature: 12.0°C
                        RPM: 1498 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ47 ELV 043 0645
       Coding: 01910A0002860E76340494157C085FCE105C04
       Shop #: WSC 00028 028 00001
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    4 Faults Found:
    01134 - Alarm Horn (H12)
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:07:17
    00332 - Control Circuit for Tank Flap
                007 - Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00110111
                        Fault Priority: 4
                        Fault Frequency: 7
                        Reset counter: 75
                        Mileage: 0 km
                        Time Indication: 0
    00625 - Vehicle Speed Signal
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:47
    01321 - Control Module for Airbags (J234)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:49
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
       Component: EZE_2         H56 1642
       Coding: 00000008
       VCID: 6FBBD3A1179EF2A2679-803A
    Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0004
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0556
       Revision: 14110009    Serial number: 0008326450
       Coding: 0202B6
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
       ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
       VCID: 6E85CEA51014FBAA6CF-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  005 0501
       Serial number: 00000003897266
       Coding: 010090
    4 Faults Found:
              [Front CAN AirBag]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 23:33:55
              [Front CAN MSG]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 75
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 21:58:31
    65793 - Supply voltage
              U1011 00 [00001001] - Voltage too Low
              [Front DCU undervoltage]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:21
    131329 - Rear Door Control Module
              B11ED F0 [00001001] - Supply Voltage too Low
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:21
    Address 53: Parking Brake        Labels: 3AA-907-801.clb
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000002096741
       Coding: 0010000
       VCID: 363526C52444836A64F-8062
    10 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 23
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 22:02:34
    Freeze Frame:
                        Voltage: 11.50 V
                        Count: 71
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02434 - Supply Voltage for Control Module for Left Channel
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01111001
                        Fault Priority: 2
                        Fault Frequency: 24
                        Reset counter: 35
                        Time Indication: 0
    Freeze Frame:
                        Voltage: 12.00 V
                        Count: 15
                        Speed: 0.0 km/h
                        Hex Value: 0x1273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    03182 - Clutch Position Sensor (G476)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 2
                        Fault Frequency: 12
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:07:25
    Freeze Frame:
                        Voltage: 11.10 V
                        Count: 55
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    01316 - ABS Control Module
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01111101
                        Fault Priority: 2
                        Fault Frequency: 11
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:49:23
    Freeze Frame:
                        Voltage: 12.00 V
                        Count: 69
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    00576 - Terminal 15
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:35:16
    Freeze Frame:
                        Voltage: 9.50 V
                        Count: 52
                        Speed: 0.0 km/h
                        Hex Value: 0x1143
                        Hex Value: 0x0008
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:35:35
    Freeze Frame:
                        Voltage: 9.50 V
                        Count: 74
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                000 - -
                 Freeze Frame:
                        Fault Status: 01110000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 98
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    01087 - Basic Setting Not Performed
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 41
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Status: 01110101
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 99
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:35:51
    Freeze Frame:
                        Voltage: 9.50 V
                        Count: 161
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
       Component: LWR-ECU       005 0030
       Revision: --------    Serial number: --------------
       Coding: 078E000001000000
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
       ROD: EV_HeadlRegulVWLWRCC_VW46.rod
       VCID: 392F2DF919DA6C1289D-806C
    2 Faults Found:
    5275648 - Left/Right Driving Switch-Over Active
              C1080 00 [00001001] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:28
    13705475 - Databus
              U1121 00 [10001001] - Missing Message
              [Timeout mMotor_1]
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 03:07:28
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
       Component: Batt.regelung H56 1642
       Coding: 030F1859
       VCID: 71BFD5D901AAE45271D-8024
       Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 31080345141491978836
    Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Component: J772__Rearview      0040
       Revision: 00H13000    Serial number: 525PA8-J430638
       Coding: 0020008
       VCID: 678BBB81336E2AE22F9-8032
    4 Faults Found:
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 21
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 03:07:35
    Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:47
    Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:48
    Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    01327 - Control Module for Parking Aid (J446)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 75
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 23:33:48
    Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    End----(Elapsed Time: 01:27, VBatt start/end: 11.1V/11.1V. VIgn 11.5V)-----
    ------------------------------56 Faults Found------------------------------
    Scan after auto clear, returning hard codes
    10-Park/Steer Assist -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
       Coding: 0010000
    7 Faults Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
    Freeze Frame:
                        Speed: 0.0 km/h
                        Hex Value: 0x0000
                        Voltage: 11.50 V
                        Bin. Bits: 00011111
                        Count: 216
                        Hex Value: 0x0000
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
       Revision: 00001K02
       Coding: 071400C849
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 P    HW: 3AA 937 087 P
       Component: BCM PQ47 H    422 0474
       Revision: BB422001
       Coding: 0008000000000000009800805400812403514E88406C87606480C7200041
       VCID: 47CB5B015FAE0AE20F9-8012
    7 Faults Found:
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:17
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.60 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    00833 - Signal for Activation of Heated Windshield
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:14
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.60 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:14
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.55 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    01520 - Rain and Light Recognition Sensor (G397)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:16
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.60 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    02092 - Enabling Heated Seat
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:41
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.55 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:14
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.55 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
    03678 - Coordinator for Start-Stop Operation
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:13
    Freeze Frame:
                            Term 15 On
                        Voltage: 11.55 V
                            ON
                            ON
                            ON
                            OFF
                            OFF
       Coding: 308004
    Cannot be reached
       Coding: 0012362
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:14
       Coding: 0182270000
       Coding: E20000
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
    UBat: 11.60 V
       Coding: 460D01
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
       Coding: 469007
    3 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:13
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:18
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:14
       Coding: 020100
    Data carrier:
    4 Faults Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:15
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:13
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:13
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Mileage: 150711 km
                        Date: 2020.10.26.
                        Time: 20:16:13
       Coding: 0202B7
       Slave Driver:
       Coding: 010090
       Revision: 00H22000
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
    Freeze Frame:
                        Battery Volts: 11.6 V
                            DU
                        Temperature: 15.0°C
                        Count: 3
                        Count: 1
                            SteerAng n.Init
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
    Freeze Frame:
                        Voltage: 11.50 V
                            DU
                        Temperature: 15.0°C
                        RPM: 1498 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    1 Fault Found:
                000 - -
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:56
       Coding: 00000008
       Coding: 0202B6
       Slave Passenger:
       Coding: 010090
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:12
       Coding: 0010000
    7 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 26
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 22:02:34
    Freeze Frame:
                        Voltage: 11.50 V
                        Count: 71
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 26
                        Reset counter: 35
                        Time Indication: 0
    Freeze Frame:
                        Voltage: 12.00 V
                        Count: 15
                        Speed: 0.0 km/h
                        Hex Value: 0x1273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:06:51
    Freeze Frame:
                        Voltage: 11.50 V
                        Count: 69
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Status: 01111010
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
    Freeze Frame:
                        Voltage: 11.50 V
                        Count: 55
                        Speed: 0.0 km/h
                        Hex Value: 0x1243
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 98
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                000 - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 41
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:00:03
    Freeze Frame:
                        Voltage: 10.10 V
                        Count: 99
                        Speed: 0.0 km/h
                        Hex Value: 0x1253
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:13
    13705475 - Databus
              [Timeout mMotor_1]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Date: 2025.10.15.
                        Time: 00:11:13
       Coding: 030F1859
       Coding: 0020008
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 484087 km
                        Time Indication: 0
                        Date: 2020.03.07.
                        Time: 00:11:12
    Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    End----(Elapsed Time: 01:27, VBatt start/end: 11.0V/11.0V. VIgn 11.4V)-----
    ------------------------------41 Faults Found------------------------------
  3. Re: VW Passat CC 2014
    #13
    135 Post(s)
    2038 Post(s)
    Join the Ross Tech forum and get your interface verified.
    One think that struck me was it looking for engine ECU 2 address 11 and address engine other, I suspect the CAN BUS coding has been played with so go into address 19, installation list and untick 11 and 31. Also untick Tire pressure monitoring address 4C, it has indirect TPMS Pr:7K6, not direct monitoring Pr:7K3; that alone will clear a lot.
    Then do a new scan and if it still won't auto scan address 09 central electrics, come out of auto scan, into address and click on it manually. Post the new scan here and on Ross Tech as well, there are some very bright types on there.
    The first step is going to be finding out why there are no ECU comms, so I would start by checking for ignition on power at pins 3, 5 and 6 (engine bay fuse 14) in the larger 94 pin plug across to pins 1, 2 and 4 and permanent power at pin 92 (engine bay fuse 13)
  4. Re: VW Passat CC 2014
    #14
    Oct 2025
    South Shields UK
    Wednesday,15,October,2025,15:32:12:16365
    Ross-Tech: Home
    VIN: WVWZZZ3CZEP009398 License Plate:
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56
    61 62 6C 72
    VIN: WVWZZZ3CZEP009398 Mileage: 484080km-300793miles
    01-Engine -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 PR HW: 03L 907 309 AE
    Component: R4 2.0l TDI H28 9980
    Revision: 41H28--- Serial number: VWZCZ000000000 CVN: 664538F3
    Coding: 00190012042501080000
    Shop #: WSC 65535 000 00000
    ASAM Dataset: EV_ECM20TDI01103L906018PR 003008
    ROD: EV_ECM20TDI01103L906018PR.rod
    VCID: 094F9D3909BABC92D9D-805C
    VINID: 9E69EAAAA0D3A958000090C9203AD6AD06
    Readiness: 0 0 0 0 X
    Coding: 0010000
    7 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 10.75 V
    Bin. Bits: 00000000
    Count: 216
    Hex Value: 0x0000
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Revision: 00001K02
    Coding: 071400C849
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Revision: BB422001
    Coding: 0008000000000000009800805400812403514E88406C876064 80C7200041
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:51
    Freeze Frame:
    Term 15 On
    Voltage: 11.00 V
    OFF
    ON
    ON
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Term 15 On
    Voltage: 11.05 V
    OFF
    ON
    ON
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:52
    Freeze Frame:
    Term 15 On
    Voltage: 11.00 V
    OFF
    ON
    ON
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:48
    Freeze Frame:
    Term 15 On
    Voltage: 11.05 V
    OFF
    ON
    ON
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:50
    Freeze Frame:
    Term 15 On
    Voltage: 11.05 V
    OFF
    ON
    ON
    OFF
    OFF
    Coding: 308004
    Coding: 0012362
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:49
    Coding: 0182270000
    Coding: E20000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    UBat: 11.10 V
    Coding: 460D01
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod (VIN: N/A)
    Coding: 469007
    Shop #: WSC 05314 123 00001
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:52
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:48
    Coding: 020100
    Data carrier:
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:51
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 150711 km
    Date: 2020.10.26.
    Time: 20:16:13
    Coding: 0202B7
    Slave Driver:
    Coding: 010090
    1 Fault Found:
    66048 - Motor for Front Window Regulator
    B11EC 54 [00001001] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Revision: 00H22000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:47
    Freeze Frame:
    Battery Volts: 11.0 V
    DD
    Temperature: 13.0°C
    Count: 3
    Count: 1
    SteerAng n.Init
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:53:10
    Coding: 00000008
    Coding: 0202B6
    Slave Passenger:
    Coding: 010090
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Coding: 0010000
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 27
    Reset counter: 35
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.00 V
    Count: 15
    Speed: 0.0 km/h
    Hex Value: 0x1273
    Hex Value: 0x0001
    Hex Value: 0x1010
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 00:06:51
    Freeze Frame:
    Voltage: 11.50 V
    Count: 69
    Speed: 0.0 km/h
    Hex Value: 0x1253
    Hex Value: 0x0001
    Hex Value: 0x1010
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 00:00:03
    Freeze Frame:
    Voltage: 10.10 V
    Count: 98
    Speed: 0.0 km/h
    Hex Value: 0x1253
    Hex Value: 0x0001
    Hex Value: 0x1010
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 00:00:03
    Freeze Frame:
    Voltage: 10.10 V
    Count: 41
    Speed: 0.0 km/h
    Hex Value: 0x1253
    Hex Value: 0x0001
    Hex Value: 0x1010
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 00:00:03
    Freeze Frame:
    Voltage: 10.10 V
    Count: 99
    Speed: 0.0 km/h
    Hex Value: 0x1253
    Hex Value: 0x0001
    Hex Value: 0x1010
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Date: 2025.10.15.
    Time: 02:49:47
    Coding: 030F1859
    Coding: 0020008
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 484087 km
    Time Indication: 0
    Date: 2020.03.07.
    Time: 02:49:46
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    End----(Elapsed Time: 01:39, VBatt start/end: 10.3V/10.2V. VIgn 10.6V)-----
    ------------------------------33 Faults Found------------------------------
  5. Re: VW Passat CC 2014
    #15
    Oct 2025
    South Shields UK
    Do i need to take the fuse box out to test these?
  1. Please Help ECU replacement - 2014 Passat
    By Alfa maverick in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 28-09-2021, 09:44 PM
  2. 2014 VW passat estate
    By sheldon1 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 30-12-2017, 04:42 PM
  3. Question VW passat 2014 B7 2.0 TDI headlights
    By fabweb in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-11-2017, 05:50 PM
  4. Question B7 2014 Passat OE retractable electric towbar
    By chiselchops in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 30-03-2017, 11:06 AM
  5. Passat Executive Style 2014
    By SteveJ73 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 17-07-2014, 01:11 PM
