Thread: P0118 sensor error - 1.9 tdi BXE - late 2007
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    I've got a strange issue with my Golf 1.9 tdi which is giving a G62 sensor fault P0118 signal too high.
    I've replaced the sensor twice with old OEM ones which I've tested the resistance of and still I cannot clear the fault.
    I've also replaced the thermostat with a Meyle, it had already had a Febi one fitted fairly recently by the looks of it.
    Also, the larger of the two fans runs as soon as you turn the ignition on, runs at high speed for about 10-15 seconds, then slows and runs fast again.
    The temperature gauge is slow to respond but does settle eventually at the 90 degree mark and VCDS reports that it's getting up to around 75 to 80 degrees.
    Also, I've looked at the instrument cluster reading in VCDS for coolant temp. and it reads -50 degrees C!!
    Is it possible that the problem could be with the ECU as I don't know the history of the vehicle but some numpty had fitted a RAMair induction kit to it which I've immediately replaced with the original airbox etc.
    I also have a 00778 fault with the steering angle sensor. If I can't do basic settings presumably that points towards the actual sensor and not the clock spring?
    Any assistance or pointing in the right direction greatly appreciated.
    Below is the full scan, I've replaced the glow plugs that were open circuit:
    Code:
    Sunday,14,September,2025,09:57:45:61478
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 25.3.2.0 (x64)
    Data version: 20250822 DS365.0
    Ross-Tech: Home
    VIN: WVWZZZ1KZ8M340151   License Plate: AJ57
    Mileage: 254510km-158145mi   Repair Order: V1
                    Address 01: Engine       Labels: 03G-906-016-BKC.clb
    Control Module Part Number: 03G 906 021 PM    HW: 03G 906 021 AN
      Component and/or Version: R4 1,9L EDC G000SG  1136
               Software Coding: 0000071
                Work Shop Code: WSC 00066 000 00000
                          VCID: 79F9C1F03029745394-802C
    5 Faults Found:
    000280 - Engine Coolant Temp. Sensor (G62)
                   P0118 - 000 - Signal too High - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 255
                        Mileage: 254109 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:13:37
                 Freeze Frame:
                        RPM: 1218 /min
                        Speed: 0.0 km/h
                        Load: 10.2 %
                        Voltage: 14.36 V
                        Bin. Bits: 00101100
                        Temperature: 24.3°C
                        Temperature: 33.3°C
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 254141 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 17:44:56
                 Freeze Frame:
                        RPM: 1449 /min
                        Speed: 3.0 km/h
                        Load: 11.4 %
                        Voltage: 14.52 V
                        Bin. Bits: 00101100
                        Temperature: 18.9°C
                        Bin. Bits: 10110000
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 11
                        Reset counter: 255
                        Mileage: 254141 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 08:59:31
                 Freeze Frame:
                        RPM: 1722 /min
                        Speed: 26.0 km/h
                        Load: 100.0 %
                        Voltage: 14.52 V
                        Bin. Bits: 00101000
                        Temperature: -3.6°C
                        Bin. Bits: 10110000
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 000 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 254141 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 08:59:53
                 Freeze Frame:
                        RPM: 1806 /min
                        Speed: 65.0 km/h
                        Load: 0.0 %
                        Voltage: 14.59 V
                        Bin. Bits: 00101100
                        Temperature: 4.5°C
                        Bin. Bits: 10110000
    006481 - Radiator Fan 2 (V177)
                   P1951 - 000 - Movement Restricted / Jammed - Intermittent
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 190
                        Reset counter: 255
                        Mileage: 254363 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 13:01:58
                 Freeze Frame:
                        RPM: 1806 /min
                        Speed: 84.0 km/h
                        Load: 46.3 %
                        Voltage: 14.44 V
                        Bin. Bits: 00101000
                        Temperature: 75.6°C
                        Duty Cycle: 86.9 %
    Readiness: N/A
  2. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    135 Post(s)
    2036 Post(s)
    I find it strange you have used a second hand G62 when a new Febi 29318 is a tenner. View the value in engine and instruments, it must be the same. The fan problem is the controller in the large fan, the small one damages it and the large one acts oddly.
  3. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    Thanks for the reply. It wasn't for me penny pinching, I just had a couple of spares and a new Meyle one and they all give the same result. I believe it may be a wiring loom break.
    Thanks re. the fans, I have a spare set of fans so I'll stick them on.
  4. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    135 Post(s)
    2036 Post(s)
    If it was wiring, I expect the code to be open/short circuit. Do you get the same value in engine, HVAC and instruments?
  5. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    Ah yeah ok, I see what you mean.
    I haven't checked HVAC, I'll try that.
    Thanks.
  6. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    So, replaced the fans and they now both run and no error, but they run constantly when engine is running. But you were correct Crasher, originals were faulty, so that's progress.
    Regarding coolant temperature, it appears to be correct in engine and HVAC at 27 degrees C and increasing albeit slowly, but in instruments it still stuck on -50 degrees C.
  7. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    135 Post(s)
    2036 Post(s)
    Is the air con turned off?
  8. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    Yeah, aircon definitely turned off. I turned it off and on acoupe of times, made no difference.
  9. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Mar 2010
    Derry ireland
    68 Post(s)
    i would suggest you remove throttle body its most likely choked up with crud a good clean up and check and replace
  10. Re: P0118 sensor error - 1.9 tdi BXE - late 2007
    Jan 2014
    Bicester
    Quote Originally Posted by mickeybo View Post
    How would that affect coolant temperature? Do you mean EGR?
  1. Please Help ABS error + radio error + air quality sensor error + CAN gateway error
    By chilly1g in forum Scirocco - 2008-
    Last Post: 29-07-2024, 10:17 AM
  2. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  3. Replies: 5
    Last Post: 28-03-2012, 10:27 AM
  4. Fault code P0118+ on Audi A4 3.0
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2011, 06:02 PM
  5. Fault code P0118
    By Fatboyjarv in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2011, 09:26 AM
