Thread: Front Bulb out - Incandescent flashing
  1. Front Bulb out - Incandescent flashing
    Sep 2025
    West Midlands
    Hi all,
    New here but I've owned my Avant 3 years now. I've a A4 B6, 2004, 1.9TDI Quattro Avant. I've a problem that started about 10 days ago that surely someone else has had.
    The dash shows N/S front bulb out and it flashes double time but the bulb still works. These are regular incandescent bulbs, non LED. So far I've tried,
    • Another 2 bulbs
    • Another headlight
    • Another hazard switch
    • Unpinned the 3 earths in the headlight connector and reassembling
    • Clean of the earth connector to the left of the battery
    All with no success. I've plugged in VCDS hoping to find a relevant error code but nothing to do with blinkers/indicators. The only light code is 16995 (Brake light switch) implausable/intermittent. That was just a sticking switch AFAIK.
    I've had suggested it maybe the CCM. Anyone else here with any ideas? Thankyou in advance!
  2. Re: Front Bulb out - Incandescent flashing
    Sep 2025
    West Midlands
    After checking module (09-Cent. Elect.), I found this error code 57-00 Electric Circuit failure.
    So, is it the headlight connector into the headlight, CCM or am I not going to know without physically wiggling the connectors?
    Anyone had anything similar?
  3. Re: Front Bulb out - Incandescent flashing
    135 Post(s)
    2027 Post(s)
    Remind me Monday so I can check the wiring diagram.
  4. Re: Front Bulb out - Incandescent flashing
    Sep 2025
    West Midlands
    Thankyou, I will. It's a fault that just started so maybe it's just bad connector somewhere? I had ordered a used CCM incase it's that. I'll probably order a new headlight connector just incase.
  5. Re: Front Bulb out - Incandescent flashing
    Sep 2025
    West Midlands
    < SOLVED >
    For those that may have a similar fault in future the left hand "bulb out" dash warning with left signals flashing fast, right normal speed.
    It turned out to be not the CCM but the BCM (Body Control Module). Swapped in another and that cured it.
    < SOLVED >
  1. front fog bulb
    By steve67 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-03-2012, 10:22 PM
  2. Question front bulb types..
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-02-2011, 08:12 PM
  3. front bulb Access
    By 1st time buyer in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-05-2009, 11:33 AM
  4. How to remove the front Turn signal bulb socket to replace bulb
    By rg0115 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 10:47 PM
  5. Front indicator bulb
    By kenw.sharan in forum Touran - Sharan - Caravelle
    Last Post: 04-08-2007, 09:39 PM
