Thread: chipped not boosting
  1. Arrow chipped not boosting
    hello again i have a problem with my chipped not boosting is there anything to do with this trouble codes
    18010 (P1602) Power Supply (B+) terminal 30 Low Voltage
    17967 (P1559) Idle speed controller
    INTERMITTENT
    does this affect the chipped to boost?
  2. Re: chipped not boosting
    134 Post(s)
    2022 Post(s)
    Engine, year?
  3. Re: chipped not boosting
    thank you fr your reply
    its 1997 passat 1.8 turbo engine code AEB
  4. Re: chipped not boosting
    134 Post(s)
    2022 Post(s)
    18010 usually just means you have had a flat battery and 17967 means the throttle body needs cleaning and readapting. Are you using a registered version of VAG-COM where you can use the output tests function?
  5. Re: chipped not boosting
    im using the shareware version anyway i just changed the battery to new about the throttle adaption i have no problem with my engine idle only problem is the fault code keep on registering
  6. Re: chipped not boosting
    134 Post(s)
    2022 Post(s)
    You won't be able to clear the code without being able to get access to Basic Settings 04. You may not think you are having an idle problem but if your ECU is registering that code, you are having a problem.
  1. unpredictable boosting for S3
    By dyeung888 in forum Audi A3 - Archive Topics
    Last Post: 01-11-2007, 05:49 PM
  2. Golf Mk4 Tdi 90 Se Chipped!!
    By golf4tdi in forum Chat - Anything with wheels
    Last Post: 08-10-2007, 04:00 PM
  3. Have you Chipped your bora?
    By peterwatkins99 in forum Bora - 1998 - 2005
    Last Post: 02-10-2007, 08:08 AM
  4. Boosting issues
    By vw_jack in forum Golf MK4 - 1999 - 2004
    Last Post: 09-08-2007, 04:42 PM
  5. Should I have Turbo whoosh /Over Boosting?
    By RGC in forum Archive posts
    Last Post: 16-05-2007, 09:34 PM
