Thread: Loom identification help please
  1. Loom identification help please
    Aug 2010
    Leeds
    Still chasing several electrical gremlins, most seem to be derived from a section of loom on the drivers side which comes from within the drivers (right hand side) foot well and out of the bulkhead and into the under bonnet fuse box which the ecu is mounted upon. (its had several crap repairs and lookes *******)
    Within this fuse box it plugs into the engine loom (Mines part no 4G2971072GF) via a red and a white connector, it then drops out the bottom of the fuse box through a grommet and into the car. Ive tried googling for part numbers to no avail and looked for 'dash looms' on eaby but cant seem to see the correct connectors on these looms of the large grommet that it should have on as it enters the engine bay?
    Anyone any ideas or a link to a loom schematic so i can track it down?
    Many thanks Joe
  2. Re: Loom identification help please
    135 Post(s)
    2031 Post(s)
    £1731.60 retail inc. no UK stock, special order from Germany and no confirmed release date BUT possibly two weeks.
  3. Re: Loom identification help please
    Aug 2010
    Leeds
    Is that for 4G2971072GF? ive forund that one ebay for £85.
    Im after the loom that connects from that into the cabin? any links to an exploded diagram of the looms? i might have to dismantle the dash to try find a part number on a tag.
  4. Re: Loom identification help please
    135 Post(s)
    2031 Post(s)
    The price was for the part number you gave and is described as the wiring set for engine, there is no official diagram, rather a generic one but I can tell more with the VIN.
  5. Re: Loom identification help please
    Aug 2010
    Leeds
    wauzzz4gxdn102601
    IVE ORDERED THE ENGINE LOOM FOR £85 AND WILL GET THAT FITTED, Ops caps!
    ive asked a breaker about the internal loom and he says the red and white plugs are part of tha main car loom not the dash loom so i might have to try get a loom cut and do nice tidy join inside somewhere?
  6. Re: Loom identification help please
    135 Post(s)
    2031 Post(s)
    It is the correct part number, this isn’t a job I would relish. I am just rebuilding the engine bay looms for a Golf 2 16v that was severely damaged when the unfused main ignition power line was crushed in the wiper motor linkage and caused the wiper motor harness to burn out right through to the fuse box, right nasty mess of dozens of wires. I have had to replace all the damaged wires from fuse box to component, even the left front headlight and outside temp sender earth.
  7. Re: Loom identification help please
    Aug 2010
    Leeds
    fitted new loom (well from a breaker) other day its still works which is a good thing! Big job i had front end off to repair the slam panel but i think you would have to remove this to change it anyway.
  1. Door loom replacement kit vs complete loom
    By ianlovatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-07-2021, 09:55 PM
  2. A4 B8 I.C.E identification
    By StuBeeDoo in forum In Car Entertainment
    Last Post: 02-09-2016, 12:05 PM
  3. Replies: 0
    Last Post: 18-02-2012, 08:06 PM
  4. Please Help relay identification
    By poppyleigh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2011, 08:49 PM
  5. Help with wiring identification!
    By DWHail in forum Bora - 1998 - 2005
    Last Post: 21-03-2010, 11:04 PM
