Thread: diagnosing a3 1.6tdi issue
  1. diagnosing a3 1.6tdi issue
    Sep 2025
    Swindon
    Hi - I have a 2013 1.6 tdi audi a3. It's done 163k miles, running beautifully and still getting great economy! My issue is that it takes a while to start from cold. There seems to be plenty of life in the original battery still (yes - has never been changed!) but wonder if the glow plugs are at fault.
    I don't get any rough idle, or the glow plug icon flashing on the dash. I do get the yellow check engine light on ignition, which then goes off when it starts. It just takes about 3 or 4 seconds of cranking to start when cold, and then when warm starts almost instantly. If I turn the ignition on and off a few times from cold to repeat the glow plug cycle a couple of times, the symptoms ease slightly.
    With winter round the corner, I'm thinking I should not let this go. Do you think the glow plugs would only be an issue IF the glow plug light comes on - which it doesn't, so this is more the battery than the glow plugs??
    Any help / advice would be appreciated.
    Julian
  2. Re: diagnosing a3 1.6tdi issue
    135 Post(s)
    2026 Post(s)
    The CAYC has active glow plug monitoring and they are used as part of the emissions strategy during normal running so in theory, a failed glow plug should cause the emissions warning light to come on when running. In my experience, it is more likely that the cranking rpm is below the critical value of 280rpm, usually down to a worn starter motor and very common with the Valeo brand. The standard test is to unplug the injectors and crank the engine over whilst observing the rpm in measuring blocks using a suitable diagnostic system. After reconnecting the injectors, the fault codes generated doing this test need to be cleared.
  1. Please Help Audi A3 1.6TDI engine issue - Not starting
    By Youngie73 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-09-2024, 09:14 AM
  2. Please Help Need Help Diagnosing 12v Socket and Rear Wiper Issue in My Golf TDI Mk6
    By sto in forum Golf MK6 - 2009 - 2013
    Last Post: 09-12-2023, 01:26 AM
  3. Help diagnosing a clutch issue please?
    By Dony-Jam in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-04-2019, 06:37 AM
  4. Diagnosing a cold start misfire issue with VCDS
    By negev in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-11-2016, 12:02 AM
  5. 2010 A3 1.6tdi sport Stop/Start Issue
    By mpgscott in forum VCDS - Help Requests
    Last Post: 24-03-2014, 08:46 PM
