Thread: A3 8L no power to ECU
  1. A3 8L no power to ECU
    Sep 2025
    Fr
    Hello, I have Audi A3 2000 1.9 TDI AHF engine code.
    I can't start it. It cranks, but no start. As I understand, it gets no power to ECU. No MIL light when ignition on, can't communicate with it on OBD. Fuses inside the car seems good, but the ones, that are for ECU or engine in general, gets only around 1volt of power. I found two relays in the engine bay, relays are good, but not activating with ignition on. Both receives 12 volt to one pin, the others have 0 volt. What to check? Can someone help? Thank you!
  2. Re: A3 8L no power to ECU
    134 Post(s)
    2022 Post(s)
    It has been a while since I worked on a PQ34 Diesel so remind me to so I can look at the wiring diagram. The engine just turns over, it doesn’t start and cut out? Have you tried a sniff of Easy Start down the breather pipe fitting to the turbo? Don’t use brake cleaner.
  1. Audi A4 B7 3.0 S-Line Cabriolet 2006 Climate Control no power, HVAC no power
    By Paulmhanna in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-07-2017, 09:54 PM
  2. Please Help Loss of power> smokey > then no smoke or power at all!! (VW Mk4 GT TDI 130)
    By v15hal in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2012, 07:24 AM
  3. Supermarket Diesel Passat B6 2.0 TDi BKP Engine Poor Power Lack of power
    By woody80uk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2012, 11:29 AM
  4. cigarette lighter power points NO POWER!?
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-08-2011, 04:20 PM
  5. Power source for Satnav / Phone Power
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 07-02-2007, 12:43 PM
