Thread: Water Ingress
  1. Water Ingress
    Aug 2008
    while driving this morning I could hear water sloshing around, more prominent when braking.
    Pulled the NSF carpet up (as far as I could) and there has to be 15-20mm of water in the floor pan - because of the chunky foam backing, the carpet has'nt got wet yet.
    Had a look in the scuttle panel - no standing water.
    Had a look under the dash, there is no obvious evidence of water marks - and this has happened over the last 48 hours, I did not drive the car yesterday at all - the front has been parked under overhanging trees.
    Are there any 'usual suspect' places where water gets in?
    '86 WR Ur quattro Tornado Red
    '2006 3.2l V6 quattro Estate
    Retrofits so far: Sat Nav, DAB, Electric folding dimming mirrors with auto dimming interior mirror
    Front and rear parking sensors, Rear parking camera, TPMS, Electric lifting tailgate
  2. Re: Water Ingress
    134 Post(s)
    2022 Post(s)
    It is usually the plenum chamber drains being blocked.
  3. Re: Water Ingress
    Aug 2008
    So I syphoned around 6 litres of water from the floor pan today - didn't have time to remove the seats and pull the carpets back!
    Had a look in the plenum chamber - think I've found the O/S drain, about 25mm in diameter - its under the brake fluid container? - it looks in bad shape, very cracked. Couldn't see another one like it - I'm just presuming there is one on each side?
    However, just to the right of this drain is a hole around 40mm in diameter - looks like it should have some form of grommet in it, but it hasn't - should it have something in it??
    I take it the drains are replaceable??
  1. Please Help Water ingress
    By muffster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-02-2018, 03:11 PM
  2. Water ingress
    By jillbrit in forum Golf MK5 - 2004 - 2009
    Last Post: 06-02-2014, 07:35 PM
  3. ECU Water Ingress
    By vwrich85 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-11-2010, 01:09 AM
  4. Question Water ingress
    By PAPPA in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 07:43 AM
  5. Water Ingress?
    By kriskros in forum Passat - Archive Topics
    Last Post: 26-12-2006, 08:09 PM
