Thread: Mk5 R32 2007 wiring woes
  1. Mk5 R32 2007 wiring woes
    Aug 2025
    Hi. I'm a total amateur when it comes to vehicle wiring and have pushed through my limits a couple of times already, hopefully not breaking anything so far, fingers crossed anyway
    MAF stopped working, figured out there was no 12v feed, traced an issue back to (I thought) a relay, n
    ew relay arrives, same problem
    Tested the relay "terminals?" and found that 85 "port?" which I believe should be earth was live with approx 3.5v
    Pulled the fuse box off and tested ports to pins on the back for continuity and everything checks (everything triggering as expected and nothing triggering that shouldn't) out so I think the fuse box is OK but now I am well stuck because my ability to interpret the wiring diagrams has reached it's limit.
    Not sure how to progress, any help, guidance or advice would be very appreciated
  2. Re: Mk5 R32 2007 wiring woes
    Aug 2025
    Actually after a bit more study of the wiring diagrams I don't understand the bits in red.
    That might of course be my not understanding the diagrams or something that's actually wrong?
    Fuse box relay slot Voltage Expected pin continuity Tested pin continuity
    85 control ground 3.5v 26/2 26/2
    86 control positive 12v 26/5 26/5, 26/7
    30 supply positive 12v Fuse 51 on fuse holder B? 40/18, 40/23, 40/27, 40/31, 40/35
    87 output 0v 26/6, 26/14, 26/19, 40/33 26/6, 26/14, 26/19, 40/33
  3. Re: Mk5 R32 2007 wiring woes
    Aug 2025
    So on further reflection my thinking is to ignore the unknown, if the problem was in the fusebox there would be some continuity between port 85 and one of the other pins?
  4. Re: Mk5 R32 2007 wiring woes
    134 Post(s)
    2021 Post(s)
    I need to be at work to study the wiring diagrams, over the years I have seen a lot of BUB engines with degraded wiring harnesses, especially in the section from box to chassis leg. Which fault codes are you getting?
  1. Please Help More Wiring Woes. Alternator D+ connection plug
    By SammoVWT in forum Golf MK3 - 1993 - 1999
    Last Post: 24-11-2020, 11:08 PM
  2. A6 2007 2.0 tdi avant starter woes.
    By norfolkandgoode in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-09-2019, 12:16 AM
  3. VW Fox 2007 - Wiring Diagram
    By chopper_harris in forum Polo - Derby - Lupo - Fox
    Last Post: 15-01-2019, 11:42 AM
  4. Gearbox woes 2007 1.9TDI 5-speed
    By johnwood1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-03-2010, 02:53 PM
  5. stereo wiring woes
    By gordnigolf in forum Golf MK3 - 1993 - 1999
    Last Post: 02-10-2008, 09:39 PM
