Thread: DSG selector switch issue on Mk3 1.2 Fabia
  1. DSG selector switch issue on Mk3 1.2 Fabia
    May 2007
    We have a 1.2 DSG auto with the ubiquitous selector switch issue common to many VAG cars with DSG boxes and intermittently throwing a B116229 error, but more usually a quick bleep on the dash and an error appearing for a second or two "Error Workshop, only leave vehicle in Position P"
    I know there are several versions of a switch kit that fit to the top of the selector housing and effectively bypass the defective switch - but I can't find a definitive view on whether any of them will fit the Mk3 Fabia, or whether there is a different solution needed.
    Any info appreciated. Thanks.
  2. Re: DSG selector switch issue on Mk3 1.2 Fabia
    2022 Post(s)
    I had two this week… what is the VIN?
  3. Re: DSG selector switch issue on Mk3 1.2 Fabia
    May 2007
    Just sent you a PM Crasher. I have had the gaiter off and it is a black topped selector, but the kit 5Q0 713 128A never lists the SKoda Fabia as suitable, only the Octavia. Cheers.
  4. Re: DSG selector switch issue on Mk3 1.2 Fabia
    2022 Post(s)
    It doesn’t show it from what I can see at home, I would need to ask TPS. All it shows is the full revised selector unit 6C2 713 025 AF at £1006.20
  5. Re: DSG selector switch issue on Mk3 1.2 Fabia
    May 2007
    A grand? Hell.
    It's clear some people with Fabia cars have had them fixed so presumably some selectors can be fixed and some cannot? See link to a Youtube video below.
    - YouTube
  6. Re: DSG selector switch issue on Mk3 1.2 Fabia
    2022 Post(s)
    Prod me tomorrow and when I ring TPS I will ask Toby to check as he is very clued up on this.
  7. Re: DSG selector switch issue on Mk3 1.2 Fabia
    May 2007
    Hi Crasher - just a follow up on this as I promised. I couldn't find any corroboration that the switch needed to be hacked about to fit the Fabia eventhough I suspect that is indeed the case, so I just had to trust my own instincts and measurements and go for it. I sealed the selector up and took a power file to the right hand side of the new switch plate, so the gaiter plate now goes on. It ain't pretty and I had to remove more plastic than I was comfortable with - almost down to the tabs. However, the switch plate still feels as secure as it did before - so only time will tell.
    So the bottom line is this would appear to explain why the 5Q0 713 128A kit is never listed as being compatible with the Fabia, but it does seem to be do-able if people are willing to take the risk.
  1. Question '06 Fabia wheel alignment - front camber issue?
    By efcbluepete in forum Fabia
    Last Post: 30-11-2016, 06:54 PM
  2. Question Fabia mk1 vrs interior light issue
    By steprosport in forum Fabia
    Last Post: 24-10-2014, 09:47 PM
  3. Switch issue
    By psj1969 in forum Golf MK3 - 1993 - 1999
    Last Post: 29-07-2010, 11:59 PM
  4. Fan Speed Selector Switch
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-05-2010, 10:47 PM
  5. headlight switch issue
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-08-2008, 08:10 PM
