Thread: EPS (power steering) yellow warning light
  1. EPS (power steering) yellow warning light
    Aug 2025
    Nottingham
    Hi all,
    I have an Audi A4 B8 which has a yellow EPS warning light along with a "Steering system fault. You can continue driving" message, which appeared 9 months ago immediately after hitting a pothole. There's no loss of power steering fluid or any loss of function to the power steering (please see photo attached).
    I asked a local garage to perform a diagnostics read and to clear the faults to see if they re-appeared. The fault that remained was U1409-00 (control unit - internal temperature) which they believed was linked to the warning light. They also suggested that this was most likely due to water ingress on the PAS control unit however I have some doubts. I don't think the warning light would appear as a result of water ingress of the control unit as the warning light appeared immediately after hitting a pothole, I would suspect it's more likely a sensor? I think water ingress on the control unit is a common fault but not leading to the warning light on my car.
    I'm looking to get a second opinion on this as I've been quoted £3k to replace the steering rack (with control unit) which would be the cost of the car... At the moment the vehicle would fail MOT.
    Billy
  2. Re: EPS (power steering) yellow warning light
    135 Post(s)
    2038 Post(s)
    It is usually water damage and was probaly pushed over the edge by the jolt. The rack is in a daft place and becomes entombed in debris which holds water, there is no way around it.
  3. Re: EPS (power steering) yellow warning light
    Aug 2025
    Nottingham
    *****, I was hoping someone would suggest it wasn't that. I'm just surprised there is no physical symptom of any issue besides the warning light itself. I would've expected if there was water ingress I'd lose some functionality of the power steering or it would be somewhat degraded.
    Thank you though!
  4. Re: EPS (power steering) yellow warning light
    135 Post(s)
    2038 Post(s)
    I have had them where they start grinding but no light or working fine but with the light on. We refuse to fit reconditioned or used parts like that after terrible experiences; time is money and failure bad for customer experience.
  1. Please Help A3 Electro Power Steering Warning Light
    By Daveyttt in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-04-2020, 01:06 PM
  2. Please Help Power steering yellow light
    By 3george in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-01-2017, 07:50 AM
  3. Question Yellow Steering Warning Light on Dash with no Symptoms.
    By ric4676 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-03-2012, 10:03 AM
  4. power steering problems and a strange warning light
    By davidh2316 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2008, 04:59 PM
  5. Fabia Power Steering warning light
    By Johnr in forum Fabia
    Last Post: 26-07-2007, 04:16 PM
