Thread: 03 alhambra auto box oil change
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 03 alhambra auto box oil change
    #11
    May 2010
    edinburgh
    Hi Steve. Getting the drain plug out isn't the issue. I don't want to take it out, and not have the correct tool to finish the job. If I had done it before then yes, I could probably cobble something together, but I haven't, that's why I am asking about draining and refilling.. I will get there eventually, one way or another.
  2. Re: 03 alhambra auto box oil change
    #12
    2018 Post(s)
    I will look it up tomorrow, remind me. From memory the level setting/full drain tube has an internal M10 hex key fitting. This is the only picture of 09B 321 363 I could find.
  3. Re: 03 alhambra auto box oil change
    #13
    May 2010
    edinburgh
    Morning Steve I think I have got it. I found a download on Clonck with good schematics and instructions for the 09B gearbox. So there is a filler at the top under the battery tray, the drain plug is a 24, and the level check is a 5 hex I am going to get it up at ramps at each corner, heat up to drain, refill then check level 35-40 degrees till its just dripping
    ...does that sound about right!
  4. Re: 03 alhambra auto box oil change
    #14
    2018 Post(s)
    I forgot to mention the car being level as with having four two post lifts I take it for granted. If you take off the upper filler plug, you need the snap off cover 01M 321 435 B, £2.52
  5. Re: 03 alhambra auto box oil change
    #15
    May 2010
    edinburgh
    I got it off and have a new one on the way. I will probably use slats of wood on top of the drive up ramps and a spirit level till its right.
    Thanks Steve, will post if its successful!
  1. Question Sorry..Another one. 04 alhambra auy auto driveshafts
    By ad777 in forum Alhambra
    Last Post: 15-02-2025, 07:39 PM
  2. Question 03 auy alhambra auto wobble
    Last Post: 19-01-2025, 01:40 PM
  3. Question Alhambra auto start/stop
    By gordonmac in forum Alhambra
    Last Post: 12-03-2017, 01:32 PM
  4. Question Alhambra 1.9 TDI PD Auto 115PS
    By matthewgdavies in forum Alhambra
    Last Post: 21-12-2010, 10:15 AM
  5. How do you change the oil on an Alhambra?
    By andy7 in forum Alhambra
    Last Post: 20-01-2010, 01:51 PM
