Thread: 03 alhambra auto box oil change
  1. 03 alhambra auto box oil change
    May 2010
    edinburgh
    Advice yet again please. I asked this ages ago, and was advised to change the gearbox oil in my automatic box I need a pump...is this a job I can attempt myself?! If so is there a certain type of pump I need to buy? And any advice on how to approach it would be greatly appreciated...there doesn't seem to be any how to videos, that I can find anyway. Cheers
  2. Re: 03 alhambra auto box oil change
    2014 Post(s)
    Depends on the box fitted, what is the VIN?
  3. Re: 03 alhambra auto box oil change
    May 2010
    edinburgh
    Vsszzz7mz4v515766
    Thanks Steve, appreciated
  4. Re: 03 alhambra auto box oil change
    May 2010
    edinburgh
    Hi Steve, I found the old post, and here's what you said...
    It is a GPE code 09B series box so the ubiquitous Jatco JF506E/F5A5. The filter is VAG part number 09A 325 429 A and is behind the sump plate. We would use the Febi 26054 filter plus you will need the gasket 09B 321 371, some companies sell the filter and gasket as a kit. The fluid is VAG G 052 990 A2 so basically GM Dexron III ATF which is easily available.
    So...I have the filter and gasket. I also have a pump that clips onto battery, to drain out of dip stip...could this be adapted to drain/ fill the oil with a suitable adapter?! Cheers.
  5. Re: 03 alhambra auto box oil change
    2014 Post(s)
    Should be OK, remember you need a diagnostic system which can show live data so you can monitor the fluid temperature.
  6. Re: 03 alhambra auto box oil change
    May 2010
    edinburgh
    Thanks Steve. 2 final questions... can you tell me which fitting I need to do the draining/ filling, and is there a video anywhere you have come across that may give me some pointers? Appreciated as always.
  7. Re: 03 alhambra auto box oil change
    2014 Post(s)
    There must be some self obsessed narcissistic shocked faces on YouTube who can spend an hour telling you their version. I can't remember the key sizes but usually 17mm hex and 8mm for the level plug.
  8. Re: 03 alhambra auto box oil change
    May 2010
    edinburgh
    Ok Steve, thanks.
  1. Question Sorry..Another one. 04 alhambra auy auto driveshafts
    By ad777 in forum Alhambra
    Last Post: 15-02-2025, 07:39 PM
  2. Question 03 auy alhambra auto wobble
    Last Post: 19-01-2025, 01:40 PM
  3. Question Alhambra auto start/stop
    By gordonmac in forum Alhambra
    Last Post: 12-03-2017, 01:32 PM
  4. Question Alhambra 1.9 TDI PD Auto 115PS
    By matthewgdavies in forum Alhambra
    Last Post: 21-12-2010, 10:15 AM
  5. How do you change the oil on an Alhambra?
    By andy7 in forum Alhambra
    Last Post: 20-01-2010, 01:51 PM
