Thread: Front suspension noise
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Front suspension noise
    #21
    Aug 2008
    OK - hear me out on this......
    As you know I'm running another post regarding the rear suspension - you pointed out that I am actually using the wrong struts AND springs..........
    It just so happens the company that supplied the wrong bits for the rear are the same company that supplied the front shocks - they were given registration and VIN on both accounts........if they got it wrong for the rears then surely getting it wrong for the fronts would'nt be too difficult for them?
    Front shocks - NK63473305
    Front springs - Original
    The front shocks look ok - no misting for example...... but that doesn't mean they are ok -
    '86 WR Ur quattro Tornado Red
    '2006 3.2l V6 quattro Estate
    Retrofits so far: Sat Nav, DAB, Electric folding dimming mirrors with auto dimming interior mirror
    Front and rear parking sensors, Rear parking camera, TPMS, Electric lifting tailgate
  2. Re: Front suspension noise
    #22
    135 Post(s)
    2036 Post(s)
    The front damper OE number is 4F0 413 031 AJ (£200.40) and again, there is nothing aftermarket that I would trust, even the Boge and Sachs listings replace multiple numbers and that isn’t right. NAPA don’t list a front damper for your car, the number NK63473305 doesn’t cross reference in TecDoc and a search shows it is for 1BV but with a 4 cylinder TDI engine.
  3. Re: Front suspension noise
    #23
    Aug 2008
    Well, finally sorted this.
    Took the plunge and bought OE from LLL parts -
    did a comparison of what I had on the car and original.....the bodies of the 2 struts are identical in length..... but the rod on the OE is 6mm shorter, the difference when attaching spring was really obvious - no more knocking!!
  1. Question UP! Noise from Front Suspension.
    By bartleaj in forum Up!
    Last Post: 12-07-2016, 10:05 PM
  2. Replies: 6
    Last Post: 31-01-2012, 04:46 PM
  3. Front Suspension Noise
    By tajgill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 10:45 PM
  4. help noise from front suspension
    By vwtdi130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2009, 09:15 PM
  5. A4 TDI 1.9 Front suspension noise?
    By tubbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2006, 12:05 AM
