Thread: EA288 / CRLB - won't start after VVT valve change
  1. EA288 / CRLB - won't start after VVT valve change
    Jul 2025
    Paris - France
    Hi Folks,
    Got a 2015 Golf Sportsvan MK7 with EA288 CRLB engine (2.0 TDI 150HP).
    Recently done myself full timing belt kit with water pump and also crank seal that was leaking oil.
    More recently, I decided to fix the apparently well known problem of long crank on 1st start of the engine, by replacing VVT valve and its housing with corrected parts. Also did Oil and its filter change, as recommanded in related VW TPI.
    Everything was good during 2 weeks, and then, it progressively degraded:
    - Long crank on 1st start reappered,
    - 3 days after, while driving, motor started to run erratic (unstable on idle or when trying to keep static rpm value, weird sounds from air intake, like air admission/compression - hard to describe)
    - Very long to start engine
    - Error codes P0011 and P0016
    At this time, I unmounted VVT valve housing and found that the little piston on the valve, the one that is actionned by the solenoid, was stuck. I unlocked it, remounted everything and motor was just running fine after that.
    I tought the VVT Valve i puchased was somehow bad (VAICO V10-7469), and won't last before getting again stuck, so I decided to unmount it to send it back and get a replacement.
    Now with a new VVT Valve replaced, i can't get engine to start at all. Can't get what is wrong, seems to me like timing is slightly wrong, didn't had time to verify this point, will do it next weekend.
    Would it be possible to have moved anything while untieding the VVT Valve? (I blocked the camshaft at TDC before proceding)
    If anybody familiar with this engine/parts/issue may help understanding what is wrong or share experience , will be gratly appreciated.
    Thank you all.
    Last edited by momohteks; Today at 08:23 PM. Reason: correction of a typo in fault codes
  2. Re: EA288 / CRLB - won't start after VVT valve change
    Jul 2025
    Paris - France
    In addition to my previous post, here is the details of fault codes i got at first:
    19233 - Bank 1: Camshaft A (Intake)
    P0011 00 [11101101] - Retard Setpoint not Reached (Over-Advanced)
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 209057 km
    Date: 2025.07.09
    Time: 13:15:58
    Engine speed: 1522.00 /min
    Normed load value: 65.9 %
    Vehicle speed: 90 km/h
    Coolant temperature: 91 °C
    Intake air temperature: 79 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 13.020 V
    Unlearning counter according OBD: 40
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 00 [11101101] - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 209096 km
    Date: 2025.07.09
    Time: 23:33:16
    Engine speed: 743.00 /min
    Normed load value: 30.2 %
    Vehicle speed: 0 km/h
    Intake air temperature: 72 °C
    Voltage terminal 30: 12.940 V
    Engine start: start synchronization: EPM_MODE_OK
    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
    I cleared the faults codes and in the present situation (engine not starting) I do not get any fault codes to investigate.
    Thanks for any help
  1. EA288 2.0 TDI Compression pressures
    By Ben_T in forum Octavia
    Last Post: 06-01-2025, 12:44 AM
  2. Question Ea288 2.0tdi crlb dpf system non adblue
    By N871BUD in forum 2.0TDi - Engine
    Last Post: 15-12-2023, 05:22 PM
  3. EA288 EVO 2.0 TDi
    By MikeBz in forum Golf MK7 - 2013 - 2019
    Last Post: 20-11-2023, 05:51 PM
  4. Vw Emissions Golf Mk 7 Mar 2013 EA288 Eur 5 engine
    By bdb in forum Golf MK7 - 2013 - 2019
    Last Post: 05-10-2015, 09:08 PM
  5. Won't start: faulty start valve?
    By Shaka1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 04:22 PM
