Thread: 2011 Golf wagon - battery drain issue with new head unit
  1. 2011 Golf wagon - battery drain issue with new head unit
    Jun 2025
    Australia
    Hi there, thanks for having me. I have a 2011 Golf wagon and was given an android/carplay compatible headunit for my birthday (thanks Dad!). The unit is this one: Attention Required! | Cloudflare
    Anyway, installation was easy and it worked well but it became apparent that it was draining my battery overnight. I have seen people talking about this issue in pre-2009 model VWs, but mine is a 2011 model so I'm not sure what to make of it. I wonder if anyone can offer any insight. The company who supplied the unit is being vague and unhelpful.
    Many thanks for your collective wisdom
  2. Re: 2011 Golf wagon - battery drain issue with new head unit
    2001 Post(s)
    If it is plug and play then there must be a CAN BUS adapter but there are no details.
  3. Re: 2011 Golf wagon - battery drain issue with new head unit
    Jun 2025
    Australia
    They do sell a CAN BUS adaptor separately (Attention Required! | Cloudflare), but it was unclear to me whether it was required for my car.
    Last night I unplugged the new unit and the battery still appeared to drain overnight (not fully, car was slow to start this morning). Maybe it was just already not very charged from the day before going totally flat though ... I'm not sure. I am going to plug the old/factory stereo back in for 24 hours and see what happens, just in case the battery drain is a whole separate issue.
    Thanks for your reply, I appreciate it.
  4. Re: 2011 Golf wagon - battery drain issue with new head unit
    2001 Post(s)
    You can’t put an aftermarket head unit in a Golf 5 onwards without using a CAN BUS adapter to provide it with the ignition on signal level command.
  5. Re: 2011 Golf wagon - battery drain issue with new head unit
    Jun 2025
    Australia
    Sorry, I wasn't very clear. It does come with a canbus adaptor but they also sell a separate one, linked above. Using the thing it shipped with doesn't seem to prevent battery drain, so I guess I need the extra one instead/also. Frustratingly I haven't been able to get a clear answer from the company... but my car started normally this morning with the old unit in place, so I assume this is the problem.
    Thanks again for your help
  1. vw golf mk5 annoying battery drain issue
    By evaldas7777 in forum VCDS - Help Requests
    Last Post: 10-12-2017, 07:24 PM
  2. Please Help Rns 315 head unit battery drain
    By wah1d in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-05-2017, 08:01 AM
  3. Another battery drain issue
    By GibGreen in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 05-11-2013, 10:55 AM
  4. Another battery drain issue
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2011, 10:47 PM
  5. MkII Golf ECU/purge valve issue - causing battery drain
    By BillyNoMates in forum Archive posts
    Last Post: 17-01-2008, 03:03 PM
