Thread: 2008/9 2.0 TDI Caga very hard brake pedal
  1. 2008/9 2.0 TDI Caga very hard brake pedal
    Jun 2025
    United Kingdom
    I’ve been doing some work on a good friend of mines and 2008 A4, the engine code is CAGA.
    Following a full service of the car by myself I was also going to try and have a look at the braking system as the pedal is super hard.
    Yesterday I did a quick test of the pedal pumping a few times when off and starting, the pedal was rock solid when off and only gave a tiny fraction when started.
    I proceeded to pressure bleed all brakes, there was air in the system but about as much as you’d expect for a brake system that hadn’t been flushed for years. All pads and discs are ok.
    This only improved the braking force slightly as we knew the sponginess would be a different symptom , and the pedal is still very stiff.
    So my next thought is potentially the brake booster? Or a vacuum leak? Or maybe master cylinder but I haven’t really heard of an MC failure.
    In terms of a vacuum leak, I cannot hear any hissing stereotypical of a vacuum leak. But there are symptoms of other items that I believe are vacuum assisted. P2015 error and P2563 error but these started throwing up way before the braking issue.
    So I would love some help with a diagnosis if others agree or can shed some light on other causes of a very stiff brake pedal on these cars. Or potentially somewhere I can get a diagram of the vacuum setup? Or any other tips in general to help me diagnose the problem.
    Any opinions would be massively appreciated, as I’d rather avoid them having to spend money on a brake booster and MC if needed.
    Thank you!
  2. Re: 2008/9 2.0 TDI Caga very hard brake pedal
    Sep 2020
    South Yorkshire, UK
    Sounds like you brake system is locking up. Are the wheels free to turn? I would flush the system to see if you have flow to each of the brakes. If so it would be the MC.
    2002 A4 B6 1.8T Saloon. Stage 1 tune, BSR exhaust, B7 320MM Brakes Brembo Disks and pads, SS brake hoses, Valeo SMF HD clutch.
  3. Re: 2008/9 2.0 TDI Caga very hard brake pedal
    Mar 2010
    Derry ireland
    67 Post(s)
    the problem with your hard brake pedal lies with your break servo either vac or servo
  4. Re: 2008/9 2.0 TDI Caga very hard brake pedal
    Jun 2025
    United Kingdom
    Quote Originally Posted by mickeybo View Post
    Thanks this is what I’m leaning towards, the brakes were flushed completely also.
  1. Replies: 4
    Last Post: 30-05-2016, 12:21 AM
  2. Hard brake pedal
    By JON35Y in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-08-2012, 03:43 PM
  3. The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    By mebedforduk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2012, 09:34 AM
  4. Hard brake pedal
    By riels in forum Ireland
    Last Post: 26-02-2010, 03:44 PM
  5. Brake pedal going hard (Please help)
    By dubstar81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2009, 08:41 PM
