Thread: Fuel Pressure Regulator life
  1. Fuel Pressure Regulator life
    Mar 2016
    Minervois, France
    54 Post(s)
    In Sept 2019 I replaced the leaking pressure regulator on my A4 B5. See post 15 onwards here Question What size pipes on petrol pump? - Page 2
    As mentioned in that link, the Audi FPR failed just after I had the same problem with our Alfa 33's FPR, which I replaced with a Malpassi AIR007 adjustable FPR supplied by jp4mance on Ebay UK, who assured me it was suitable for petrol containing alcohol. which is 5% or 10% in France.
    The Alfa's FPR just failed, not only leaking fuel directly into the inlet manifold, but shedding rubber particles which seem to be blocking the injectors. The image shows the underside, which is in contact with the petrol, and the light patches are where rubber has flaked off. The other side is red rubber, which I think was bonded on to the black, but partly separated, with a small hole in it.
    Just over 6 years does not seem to me to be much of a life for this item, as the original parts seem to have lasted 25 years in the Alfa and 23 in the Audi. I bought the Alfa in 2010 and the Audi in 2016, so I know they were not changed between then and 2019.
    I am now concerned that the Audi FPR will be similarly damaged, so have decided to replace it rather than take a chance.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: Fuel Pressure Regulator life
    132 Post(s)
    1979 Post(s)
    I have seen a few FPR’s damaged by E10, it should not be used on anything that isn’t specifically approved for its use. Ethanol for fuel from food stocks… more enviro ******** and immoral.
  1. fuel pressure regulator p2294 epc
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 12-06-2013, 02:30 PM
  2. How To Chande a fuel pressure regulator, and a bit more
    By comfortablynumb in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2009, 12:50 AM
  3. Question 4 Bar Fuel Pressure regulator.
    Last Post: 19-07-2009, 03:29 PM
  4. replacement fuel pressure regulator!!
    By 80quattro1987 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-06-2009, 10:52 AM
  5. Fuel Pressure Regulator
    By prokon in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-07-2008, 10:30 PM
