Thread: LED reverse bulb
  1. LED reverse bulb
    Mar 2012
    Birmingham
    Hi All my car is a 2010 1.4 tfsi 3 door
    has anyone successfully used a led for rear reverse light ie no warning on dash (canbus error)
    if so what bulb did you use?
    many thx in advance
    Dave
  2. Re: LED reverse bulb
    131 Post(s)
    1979 Post(s)
    There should be an option in the Long Coding table to un tick hot bulb monitoring.
  3. Re: LED reverse bulb
    Mar 2012
    Birmingham
    Thx for your reply but it’s not the hot bulb monitoring it’s the cold monitoring every time I start the car I’ve tried vcds but not able to switch cold monitoring off as there is no option to as 2010 was the year that changed grrr so annoying
  4. Re: LED reverse bulb
    131 Post(s)
    1979 Post(s)
    I haven't got an 8P here to check but I know it does vary by BCM age. You could put a resistor to each on the black/red to the light unit. To determine the value (R), you need to know the current (I) a 382 bulb draws, theoretically the rated power (P) is 21 watts and the nominal voltage (V) is 12 volts (ideally check the voltage by back probing the incandescent bulb first) so Ohm's law V=IR is rearranged to give I=P/I gives you a nominal value of 1.75 amp and rearranging the formula to R=V/IR = 12/1.75=6.857. You need a resistor with a factor of safety of 2 so a 6.8 ohm 50w bolt down (to dissipate heat) resistor would be ideal. If it was for a constant use, I would also add some thermapath underneath to help dissipate heat.
  5. Re: LED reverse bulb
    Mar 2012
    Birmingham
    Thx for the info Crasher
  1. Reverse Light bulb brightness
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-01-2017, 09:08 PM
  2. Question Problem with Reverse Bulb Warning light
    By Indepent in forum Passat CC
    Last Post: 31-05-2016, 03:23 PM
  3. Please Help Reverse bulb failure warning
    By Joe Jones in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-02-2016, 12:08 PM
  4. Reverse light bulb
    By Q7quattro in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2015, 08:13 PM
  5. Golf Mk6 Nov 2009 reverse light bulb
    By ssaini in forum Golf MK6 - 2009 - 2013
    Last Post: 27-06-2012, 12:02 AM
