Thread: 2015 Audi 2.0 TDI CNHA - Black smoke
  1. 2015 Audi 2.0 TDI CNHA - Black smoke
    May 2025
    Sweden
    Good evening esteemed forum members
    I recently acquired a bit of a problem child of a car for a proper (hopefully) steal.
    It had been stage 1 tuned, DPF off and Adblue off.
    When i bought it, it ran rough and low power across the whole band, with thick white smoke intermittently, and heavy black smoke on full pedal.
    I was hoping it was something as simple as a bad tune, so i called in a favor and had the ECU flashed to an original file.
    It runs significantly better, and the intermittent smoke is reduced, so is the black smoke, but it’s still there.
    I have had it logged, and on full pedal the lambda reads a steady 0.85, which seems very low.
    So heres what i know so far:
    DPF is emptied out, but still in position with all the original sensors etc.
    EGR is still there
    Turbo was replaced by previous owner, aswell as some other things, i’m getting a list by the shop who did it.
    On DTC scan i get this:
    P0405 EGR valve position low input
    P0403 EGR circuit malfunction
    P0420 Cat converter bank 1 low efficiency
    P204B Reductant pressure sensor
    I have CEL and the Adblue no start in 1000km warning.
    Since the DPF has been emptied i know i will need a custom map, and i fully plan on blanking the EGR and turn off Adblue aswell. But i would like to rule out any other problems before doing this to avoid issues down the line.
    Any ideas?
  2. Re: 2015 Audi 2.0 TDI CNHA - Black smoke
    131 Post(s)
    1978 Post(s)
    Quote Originally Posted by DoctorTox View Post
    I won't help with cars where this has been done.
  3. Re: 2015 Audi 2.0 TDI CNHA - Black smoke
    May 2025
    Sweden
    Well, right now it’s bonestock, except for the cleared out DPF. If i could find a new DPF for a reasonable price i would have it fitted, removes any headaches about not passing MOT.
    As i stated in the post, i want to fix any issues with it, and if i can have it running good without any modifications i’d be happy to.
  1. Please Help Audi 80 b4 66kw monopoint black smoke
    By Shoondra in forum 80 - 90
    Last Post: 23-11-2016, 04:14 PM
  2. Audi black smoke maybe turbo,
    By fowkes in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-06-2014, 09:22 AM
  3. audi a4 1.8t black smoke
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2010, 07:08 PM
  4. Audi 2.5 Black Smoke Help
    By wadi110 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-11-2008, 09:01 PM
  5. Audi A4 TDi excessive black smoke
    By bluetomb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2008, 02:10 PM
