Thread: Timing Chain replacement P0016 Code - Advice
  1. Question Timing Chain replacement P0016 Code - Advice
    Sep 2009
    South Wales
    Afternoon all,
    Been a while, hope youre all well! I don't have the Mk3 anymore but I've had a mk6 (CAXA) for a while. I'm after a bit of advice as I'm not as familiar with these by a long stretch.
    Been nursing this car through life and its just hit 72 k miles and was getting pretty rattly on startup. Opted for a chain kit and waterpump replacement because I suspected some chain stretch and worn tensioner as it wasnt holding tension overnight. It was taking longer to settle down after startup. Booked it into the garage, they had the wrong kit arrive so it was in the shop for an extra day. Got delayed again as they wanted to replace the crank sensor for a genuine part (I was told), I was confused as to why they might need this but they said it wouldn't cost me, so fair play.
    Got the car this morning, no codes. Took it for a much needed run to the shop to buy food, on the way back it tripped the check engine light on the dash.
    Scanned the car P0016 fault. Crank Cam position correlation error. I'm guessing this happened the first time when they opted for the sensor. Sensor came in, and i'm assuming they cleared the fault and drove it over to me assuming it would resolve itself. So I didn't see it at the time of them handing the car over.
    Had no issues with this fault previous to chain/pump change, so assuming sensors weren't bad at the time - am I right to think that the timing is off by a tooth or so when they have installed it? They have opted to pick the car up Tuesday to take it back in - sucks but it is what it is. They seem like a nice bunch, i'm just assuming its one of those things that gotten missed. I'm just after getting my car back on the road as its sorely missed for daily life right now.
    Long story short - Unsure of the chances that it is a genuinely faulty sensor on either crank or cam. In my mind it it needs re-timing since no correlation faults happened on the way in to the garage, so assuming its slightly off timing, am I wrong or what are the chances its a genuine sensor fault? Any thing they need to look out for? I'm guessing they dont deal with VAG cars daily for this sort of thing.
    Advice welcome.
    Codes:
    Engine:
    1/2 - 00010 - Camshaft position slow response
    2/2 -00022 - Crankshaft position-camshaft position correlation bank 1 sensor A
    OBDII
    1/3 - P0016 - Crankshaft position-camshaft position correlation bank 1 sensor A
    2/3 - P000A - A Camshaft position slow response bank 1
    3/3 - P0016 - Crankshaft position-camshaft position correlation bank 1 sensor A
    I left the firing order of the faults in. I wish I had a scope to pull the timing off, but had to use my handheld scanner for now.
    Thanks in advance!
    Sammo
    Current: Golf VI 1.4 TSI
    Past: (Beloved) Mk3 "1.6" - 184 k miles. Now a cube in scrapyard heaven :'(
    I need all your V-Powers.
  2. Re: Timing Chain replacement P0016 Code - Advice
    134 Post(s)
    2009 Post(s)
    Indeed, why would the crank speed sensor be involved, it is at the other end of the engine?
    The sensor isn't at fault, it is working as if it didn't the engine would not run. My expectation is they don't have the tools and did it Tipex and pray.
  3. Re: Timing Chain replacement P0016 Code - Advice
    Sep 2009
    South Wales
    Cheers, Crasher - your sage wisdom is always welcome.
    I suspected something like that but glad its not just me thinking it. I haven't made war with them yet - fingers crossed they take the weekend to order the proper tools in...
  4. Re: Timing Chain replacement P0016 Code - Advice
    134 Post(s)
    2009 Post(s)
    Quote Originally Posted by SammoVWT View Post
    What you really mean is I an old git…
  5. Re: Timing Chain replacement P0016 Code - Advice
    Sep 2009
    South Wales
    Some good news on this (so far). Got the wheels back yesterday, thanks to your advice I was able to have a chat with the mechanic and got him to look over the VVT system. I wont know for sure if it was timing, but he did mention he 'cleaned some junk' out of the VVT, and cleaned the sensors connectors up.
    I think it was the former that did it. But thanks Crasher, appreciate your words on this - it gave me something to go on when trying to figure it out.
    Its amazing how much having chain slack ruins the performance, that original tensioner is a crime to engineering. Nevermind, all sorted now
  6. Re: Timing Chain replacement P0016 Code - Advice
    134 Post(s)
    2009 Post(s)
    I remember back when Jaguar were announcing their Ingenium engines and how proud they were about chains and long life servicing... they are now paying the price.
  1. Question VW Sirocco timing chain tensioner replacement?
    By freakyshadows in forum Scirocco - 2008-
    Last Post: 14-01-2020, 09:48 PM
  2. Seat 1.2 Timing Chain replacement
    By jalz in forum Ibiza - Cordoba
    Last Post: 21-12-2015, 11:27 PM
  3. Question 1.4 TSI engine faults p0016/p2293 is this the Cam chain?
    By fredthedog in forum Golf MK5 - 2004 - 2009
    Last Post: 07-09-2014, 11:29 AM
  4. Question Touran Faults p0016/p2293 - Cam chain? (Same as Golf?)
    By fredthedog in forum Touran - Sharan - Caravelle
    Last Post: 04-09-2014, 09:03 PM
  5. A3 3.2 Timing Chain replacement
    By tomellis69 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-12-2009, 12:19 PM
