Thread: Radiator fans run from start to stop
  1. Radiator fans run from start to stop
    May 2017
    Dublin
    My radiator fans turns on the minute the car starts and they keep spinning until the car is turned off. This happens irrespective of the engine being hot or cold. Did a scan and saw these two faults. Not sure how they can be related:
    1 Fault Found:
    4339 - Implausible Data Received from HVAC Control Module (J301)
    U0424 00 [00100111] - -
    [Invalid Data Received From HVAC Control Module]
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 333157 km
    Date: 2025.05.17
    Time: 10:53:54
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 37 °C
    Intake air temperature: 19 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 11.980 V
    Unlearning counter according OBD: 40
    Crankshaft speed (RPM): 0.0 /min
    Vehicle speed: 0.00 km/h
    Accelerator position: 0.00 %
    Vehicle voltage terminal 30: 11980 mV
    Sig Reset Env x Id-Bits 0-7: 0
    Coolant temperature: 37.0 °C
    A/C compressor torque: 0.0 Nm
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 HW: 4F2 820 043 L
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000034 Serial number: 00000030536856
    Coding: 0001044
    Shop #: WSC 02325 785 00200
    VCID: 5BE265DF2F215E02BA8-800E
    1 Fault Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 38
    Mileage: 333157 km
    Time Indication: 0
    Date: 2025.05.17
    Time: 10:53:51
    I first suspected coolant temp sensor but the reading looks OK. Then I suspected the Fan control module but the output tests in VCDS were able to switch the fans on and off during the tests. So not sure what could be wrong here.
    Does the A/C pressure sensor has an impact on the radiator fans? My A/C has not been working for a long time and the A/C Pressure/Temperature Sensor (G395) error has been there for a while, but the "fans constantly ON" issue is new. The Implausible Data Received from HVAC Control Module (J301) is a new fault, could that be the cause? TIA
    My car: 2010 A6 C6 facelift 2.0 TDI Engine code CAGB
  2. Re: Radiator fans run from start to stop
    Mar 2010
    Derry ireland
    67 Post(s)
    The cooling fans on your vehicle has to be controlled so that allowes the engine to maintain a contant tempature.The 2 temperature sensors 0nyour vehicle has to be checked out to allow the ecu to control your fans
  3. Re: Radiator fans run from start to stop
    May 2017
    Dublin
    Quote Originally Posted by mickeybo View Post
    Thats what the output tests on VCDS do. When you run the tests, I can see the fans get turned off and then turned on again. That would indicate the fans are controllable.
    Which 2 temp sensors are you talking about?
  4. Re: Radiator fans run from start to stop
    134 Post(s)
    2012 Post(s)
    Can you post a full car scan and include the VIN?
  1. Question Radiator fans run seconds after start up
    By Seat Driver 1 in forum Touran - Sharan - Caravelle
    Last Post: 30-09-2014, 09:02 AM
  2. Question Radiator fans On/Off
    By kog in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-03-2012, 04:52 PM
  3. radiator fans
    By ambisingh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-06-2011, 11:32 AM
  4. Radiator Fans
    By vespapete in forum Golf MK4 - 1999 - 2004
    Last Post: 31-10-2008, 08:12 PM
  5. fans on radiator
    By charles0106 in forum 80 - 90
    Last Post: 07-10-2007, 06:38 PM
