Thread: Audi adblue update 23WA-S
  1. Audi adblue update 23WA-S
    May 2018
    Kent
    7 Post(s)
    Good day
    Cars gone in today for its s-tronic oil change and a fuel filter. They’ve said there’s an update due, 23WA-S, which they say is to ensure that any issues with the adblue system are displayed in the car rather than only being revealed under a full diagnostic scan.
    Car runs fine and advlue consumption has been steady at 500 miles per litre (ish).
    A quicksearch throws up a couple of posts on other forums suggesting that post update cars have lost performance and adblue and fuel consumption has increased.
    I’ve declined the update for now, is that sensible or should i have it applied?
    cars an avant, facelift , stronic, 2015 ultra.
    any insights appreciated.
    tia phil
  2. Re: Audi adblue update 23WA-S
    May 2018
    Kent
    7 Post(s)
    They say that this update is necessary to maintain your DPF and catalytic converter and to comply with the latest emissions regulations. Do you know what happens? They install new software and this increases the EGR rate. The effect is that your engine is then supplied with more exhaust gases at partial load and internal sooting increases. At first this does reduce emissions, but in the long term the engines have to contend with the problems that sooting brings with it: poor performance and jerking combined with increased fuel consumption. This also affects the lifespan. I have been able to revoke my vehicle so far. You have to sign for it. The same applies to VWs of these models. As long as possible - three years so far - I will keep my vehicle away from these measures. Good tuning specialists are familiar with the problem and can "improve" this measure. I am sure that there will be many dissenting voices now. Wait and see. But do your research beforehand because this update cannot be reversed.
    apologies for the format, it’s from copying from google translate, does the above seem plausible?
  3. Re: Audi adblue update 23WA-S
    May 2018
    Kent
    7 Post(s)
    Good day, info seems a bit thin on the ground, but from a german forum, (via google translate) its suggested that the update is to “improve” the emmissions by increasing the egr rate, which initially improves emissions but down side is increased carbon build up in the engine and ancillaries.
    Despite declining the update in the dealership, they are now calling asking me to confirm this in writing, i’ve again asked for full details of what the update does and again they say it is to ensure all faults with the adblue system are displayed on the dashboard rather than just stored in the system.
    Does anyone know what I should be asking for in terms of a full disclosure of what the update does?
  4. Re: Audi adblue update 23WA-S
    131 Post(s)
    1978 Post(s)
    The AdBlue system on the Ultra is a joke, not fit for purpose. We had one in earlier this week, no warnings other than the light so he had kept driving as no one could fix it. He drove all the way up here from Milton Keynes only for me to tell him the CAT and DPF are toast and mega money to fix, the DPF is SO huge you have to left and move the engine to the left to get the thing out!
  5. Re: Audi adblue update 23WA-S
    May 2018
    Kent
    7 Post(s)
    Cheers Crasher, armed with the knowledge i have now i’d never have bought a diesel and instead gone for a tfsi , but too late for that. In an attempt to stave off problems for as long as possible, i’ve only used bp ultimate or shell vpower ( vpower almost exclusively for last 3 years) and oil changes at 9k or annual. Then try to use it to avoid clogging it up with too many shoort runs between longer journeys. ( though taking it up the m2 and back just for the sake of it makes a mockery of any supposed efficiency , let alone time wasted)
    Round my way, no independent garage wants to get involved in much beyond the traditional mechanical side of things, my local vw specialist wouldn’t even do the s-tronic oil change. ( that said audi were Ł260 with a courtesy car, which every 40k doesn’t seem too outrageous, the shroud and actuator parts for the fuel flap were Ł63.48 (i fitted them) so again hardly end of world pricing).
    Is there any reason to think the software upgrade will improve the adblue systems reliability? Reading a few other german and italian forums seems to suggest 23-WA is more about VW/Audi dealing with their emissions shenanigans than inproving the vehicles and that performance is reduced and adblue consumption increased.
    In the absence of any positive info i’ll keep declining it. Though it’s unlikely to go to an audi dealer until the cam belt needs doing in 40k.
  6. Re: Audi adblue update 23WA-S
    131 Post(s)
    1978 Post(s)
    I think the update was more about adBlue range than anything as it was fudged to make the fluid last between services because the tank was too small and Mericans found it annoying to top up
  7. Re: Audi adblue update 23WA-S
    May 2018
    Kent
    7 Post(s)
    Hard to see why putting adblue in is such a hardship.
    That aside sometimes you can’t make things up. Returning from a day out, engine management light comes on. Finish rest of journey and plug in my foxwell ( i realise its cheap and nasty, but has done all i’ve needed)
    Throws up a 19226 Code
    200 miles since last regen ( seems odd as fans overran yesterday, but today was 110 miles each way so was not too bothered, is that figure the mileage since previous completed regen?)
    calculated soot mass 11.8 grammes
    particulate filter oil ash volume 0.1 l
    DPF differential pressures. At tickover 19 hpa
    Stationary 2500 rpm 58 hpa
    Back to tickover. 11 hpa
    Gives adblue as having 1800 miles til deficiency , which from my notes means i’m still at about 500 miles per litre which is consistent with use since i bought it.
    Bought with 38k on it in 2018, now has 112k. I’ve been careful about the adblue, fuel and use ( ie longer run if its been mostly short runs for a week or so) but no idea how original owner used it ( though only time the particulate icon came up on dash was a week after i bought it , so suggests they were’nt too careful).
    A quick google shows getting the adblue injector out is easy enough, is there any obvious way of seeing if its been dribbling?
    I’ll see if i can get a proper scan arranged , but my local vw/audi independent is a bit busy and it might take a week or two. Any obvious things i should check?
    Searching on here suggests it’s a dpf out for a clean , would that seem about right?
  1. Adblue injector location? Audi A6 Allroad 3.0 BiTDI C7 (2016 UK)
    By -MONKEY- in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-01-2025, 03:34 PM
  2. Please Help Audi s3 virtual cockpit help - feb 2021 update procedure Audi ODIS - ppl knocked back
    By adgleeson1978 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 13-10-2021, 06:59 AM
  3. Audi A5 Adblue / ECU error?
    By kiranpithwa in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-10-2021, 11:40 AM
  4. Adblue - Oddity and ECU software update
    By danclyon in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-07-2021, 02:24 PM
  5. Replies: 1
    Last Post: 01-10-2020, 05:01 PM
